Up to 20% off select tools
Unbranded UB-15MS10 Back Camera Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
34
All Time:
990
Comments: 4
4 comments on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
This guide explains how to replace the back camera on the Unbranded Tablet.
    1. Unbranded UB-15MS10 Back Camera Replacement, Back Panel: step 1, image 1 of 1
      • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
      Ask FixBot
    2. Unbranded UB-15MS10 Back Camera Replacement: step 2, image 1 of 1
      • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
      Ask FixBot
    3. Unbranded UB-15MS10 Back Camera Replacement: step 3, image 1 of 2 Unbranded UB-15MS10 Back Camera Replacement: step 3, image 2 of 2
      • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
      • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
      Ask FixBot
    4. Unbranded UB-15MS10 Back Camera Replacement: step 4, image 1 of 1
      • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
      • As the gaps open, slide the guitar picks along the sides to separate the panels.
      Ask FixBot
    5. Unbranded UB-15MS10 Back Camera Replacement: step 5, image 1 of 1
      • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
      Ask FixBot
    1. Unbranded UB-15MS10 Back Camera Replacement, Back Camera: step 6, image 1 of 1
      • Remove the small piece of black tape.
      Ask FixBot
    2. Unbranded UB-15MS10 Back Camera Replacement: step 7, image 1 of 1
      • Remove the black 4-mm #0 screw.
      Ask FixBot
    3. Unbranded UB-15MS10 Back Camera Replacement: step 8, image 1 of 1
      • To finish removing the camera, disconnect the camera ribbon from the white ZIF connector on the motherboard.
      • There are two very small prongs on the side which need to be pushed towards the center of the connector to remove it.
      Ask FixBot
4 other people completed this guide.
Author
with
Jordan Turk
331 Reputation
2 Guides authored
IUPUI, Team 2-1, Baechle Fall 2015 Member of IUPUI, Team 2-1, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G1
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 34
All Time: 990
