Up to 20% off select tools
UnBranded UB-15MS10 Back Panel Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
30
All Time:
1,681
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
The following steps show you the basics to opening up the device.
    1. UnBranded UB-15MS10 Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
      Ask FixBot
    2. UnBranded UB-15MS10 Back Panel Replacement: step 2, image 1 of 1
      • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
      Ask FixBot
    3. UnBranded UB-15MS10 Back Panel Replacement: step 3, image 1 of 2 UnBranded UB-15MS10 Back Panel Replacement: step 3, image 2 of 2
      • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
      • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
      Ask FixBot
    4. UnBranded UB-15MS10 Back Panel Replacement: step 4, image 1 of 1
      • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
      • As the gaps open, slide the guitar picks along the sides to separate the panels.
      Ask FixBot
    5. UnBranded UB-15MS10 Back Panel Replacement: step 5, image 1 of 1
      • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
      Ask FixBot
8 other people completed this guide.
Author
with
Andrea Hammans
579 Reputation
1 Guide authored
IUPUI, Team 2-1, Baechle Fall 2015 Member of IUPUI, Team 2-1, Baechle Fall 2015
IUPUI-BAECHLE-F15S2G1
3 Members
36 Guides authored
1 Guide Comment
Thanks you, work good for me.
Cesar Alvarez - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 1,681
