Ugreen NASync DXP2800 3.5" Hard drive Replacement
  1. Ugreen NASync DXP2800 3.5" Hard drive Replacement, Unlock the drive bays: step 1, image 1 of 2 Ugreen NASync DXP2800 3.5" Hard drive Replacement, Unlock the drive bays: step 1, image 2 of 2
    • First we need to unlock the bays to remove them. You can either use the included key or if you have misplaced it then a flathead screwdriver will suffice.
    • Then, you can press the buttons and pull the bays out.
    Ask FixBot
  2. Ugreen NASync DXP2800 3.5" Hard drive Replacement, Installation: step 2, image 1 of 2 Ugreen NASync DXP2800 3.5" Hard drive Replacement, Installation: step 2, image 2 of 2
    • Press the button to expand and pull the bay open
    Ask FixBot
  3. Ugreen NASync DXP2800 3.5" Hard drive Replacement: step 3, image 1 of 1
    • Place the drive into the caddy, making sure to line the nubs in the caddy with the screw holes in the drive.
    Ask FixBot
  4. Ugreen NASync DXP2800 3.5" Hard drive Replacement: step 4, image 1 of 2 Ugreen NASync DXP2800 3.5" Hard drive Replacement: step 4, image 2 of 2
    • Close the caddy, making sure that everything is seated properly.
    Ask FixBot
  5. Ugreen NASync DXP2800 3.5" Hard drive Replacement, Reinstall drives: step 5, image 1 of 1
    • Slide both caddies back into their respective bay.
    Ask FixBot
  6. Ugreen NASync DXP2800 3.5" Hard drive Replacement: step 6, image 1 of 1
    • Now you are done.
    Ask FixBot
Finish Line
Duck
6,185 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 30
All Time: 84
