Ubuntu Linux Fixing Crackling/Glitching Audio
Views: 5.5K
View statistics:
Past 24 Hours:
17
Past 7 Days:
111
Past 30 Days:
393
All Time:
5,462
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Are you experiencing a crackling sound when playing games in Ubuntu, especially during higher levels of CPU usage? Modifying your pipewire settings may fix the problem. This guide will show you how to locate and modify your pipewire settings to help resolve crackling audio issues.
Note: This guide will be using Konsole, the default terminal for Kubuntu systems. You may use another terminal if you wish.
    1. Ubuntu Linux Fixing Crackling/Glitching Audio, Ubuntu Linux Fixing Crackling/Glitching Audio: step 1, image 1 of 1
      • Open your terminal and type sudo nano /usr/share/pipewire/pipewire-pulse.conf
      • Press enter. If you are prompted for your password, enter your device's password and press enter.
      • You now have access to your pipewire settings!
      Ask FixBot
    2. Ubuntu Linux Fixing Crackling/Glitching Audio: step 2, image 1 of 1
      • Press Ctrl + W to search for pulse.min.quantum and press Enter.
      • You should find a line that says #pulse.min.quantum = 128/48000 # 2.7ms
      • Remove the first '#' at the beginning of the line and change the number 128 to 256.
      • To save your new settings, press Ctrl + X, then Y, then Enter.
      Ask FixBot
    3. Ubuntu Linux Fixing Crackling/Glitching Audio: step 3, image 1 of 1
      • Test your new settings to see if the crackling continues.
      • If the crackling is gone, great! If not, repeat the previous step but change the number 256 to 512. Then test again.
      Ask FixBot
If you'd like to reverse the changes made in this guide, go through the steps again but change the new number to 128 and add a '#' back on the beginning of the line.
Lynx
779 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 111
Past 30 Days: 393
All Time: 5,462
