Ubiquiti Cloud Key Gen2: How to replace faulty battery
  1. Ubiquiti Cloud Key Gen2: How to replace faulty battery, Battery and Harddrive: step 1, image 1 of 1
    • Because of the original batterys special form factor it was impossible to find sth that fits. I found a Lithium battery from a model aircraft shop with 7.4 V and 280 mA
    Ask FixBot
  2. Ubiquiti Cloud Key Gen2: How to replace faulty battery: step 2, image 1 of 1
    • Because this battery is larger than the original one I decided to mount it in the HD cage. I replaced original HD with a Samsung SSD. Take out the SSD of its housing for having more space. As you can see I mount a cable from the place of the original battery to the new place in the HD cage. The SSD will be auto formated by the system !
    Ask FixBot
  3. Ubiquiti Cloud Key Gen2: How to replace faulty battery: step 3, image 1 of 1
    • Soldering the original battery connector to the cable. Battery has 3 lines
    Ask FixBot
  4. Ubiquiti Cloud Key Gen2: How to replace faulty battery: step 4, image 1 of 1
    • Replacement battery fixed with cable ties. I wrote down the colour assignment of my cables and put it in the HD cage.
    Ask FixBot
  5. Ubiquiti Cloud Key Gen2: How to replace faulty battery: step 5, image 1 of 1
    • ...the old battery
    Ask FixBot
  6. Ubiquiti Cloud Key Gen2: How to replace faulty battery: step 6, image 1 of 1
    • mission accomplished :-)
    Ask FixBot
  7. Ubiquiti Cloud Key Gen2: How to replace faulty battery: step 7, image 1 of 2 Ubiquiti Cloud Key Gen2: How to replace faulty battery: step 7, image 2 of 2
    • After some weeks of not using the device the shutdown function did not work. After checking some UI forums I found out there is a circuit board inside the dead battery.
    • I also found 2 LiPo cells with the suitable Watts and Voltages. Unfortunately my charging board is faulty. So I did further test with ordinary alkaline batteries.
    Ask FixBot
  8. Ubiquiti Cloud Key Gen2: How to replace faulty battery: step 8, image 1 of 1
    • I testet 6x AAA batterys. This scenario also works, but there will not be enough space in the HD caddy. Finally a 9 V battery block did the job.
    Ask FixBot
    • As I found out the newest generation of Cloud Keys is produced with no battery. I just had 2 new CKs, both switched off immediately when loosing PoE power. It seems with new Unifi OS the device can deal better with powerloss.
    Ask FixBot
    • Nevertheless I suggest changing the 2.5" HD with a 2.5" SSD and doing safe backups of your config. USV powering of PoE switch is recommendable.
    Ask FixBot
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 66
Past 30 Days: 221
All Time: 3,454
