UTStarcom XV6700 External Speaker Replacement
    1. UTStarcom XV6700 External Speaker Replacement, Battery: step 1, image 1 of 1
      • Press the on/off button on the top to power the phone off.
      Ask FixBot
    2. UTStarcom XV6700 External Speaker Replacement: step 2, image 1 of 1
      • Remove the battery cover by pressing and sliding the cover down and off of the phone.
      Ask FixBot
    3. UTStarcom XV6700 External Speaker Replacement: step 3, image 1 of 3 UTStarcom XV6700 External Speaker Replacement: step 3, image 2 of 3 UTStarcom XV6700 External Speaker Replacement: step 3, image 3 of 3
      • Pull the battery removal tab and lift the battery out of the phone.
      • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
      Ask FixBot
    1. UTStarcom XV6700 External Speaker Replacement, Camera: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
      Ask FixBot
    2. UTStarcom XV6700 External Speaker Replacement: step 5, image 1 of 2 UTStarcom XV6700 External Speaker Replacement: step 5, image 2 of 2
      • Use firm pressure to carefully pry off the cover with your fingers.
      Ask FixBot
    3. UTStarcom XV6700 External Speaker Replacement: step 6, image 1 of 1
      • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
      Ask FixBot
    4. UTStarcom XV6700 External Speaker Replacement: step 7, image 1 of 1
      • Gently pry off the camera flash circuit board with the spudger.
      Ask FixBot
    5. UTStarcom XV6700 External Speaker Replacement: step 8, image 1 of 1
      • Gently pry off the camera with the spudger.
      Ask FixBot
    1. UTStarcom XV6700 External Speaker Replacement, External Speaker: step 9, image 1 of 1
      • Remove the four 5.0-mm Torx T6 screws from the corners of the black cover.
      Ask FixBot
    2. UTStarcom XV6700 External Speaker Replacement: step 10, image 1 of 1
      • Remove the 4.0-mm #00 Phillips screw that holds the wireless antenna in place. The antenna does not need to be removed.
      Ask FixBot
    3. UTStarcom XV6700 External Speaker Replacement: step 11, image 1 of 3 UTStarcom XV6700 External Speaker Replacement: step 11, image 2 of 3 UTStarcom XV6700 External Speaker Replacement: step 11, image 3 of 3
      • Use the spudger and plastic opening tools to apply firm but gentle pressure equally around the outside of the case.
      • Carefully pry the black portion of the case away from the silver portion.
      • Do not try to remove case completely. The speaker wire is still connected to the motherboard.
      Ask FixBot
    4. UTStarcom XV6700 External Speaker Replacement: step 12, image 1 of 1
      Buy
      • Using tweezers, pull on the connector or wire in the direction of the wire with gentle pressure to unplug the wire connector from the motherboard.
      Ask FixBot
    5. UTStarcom XV6700 External Speaker Replacement: step 13, image 1 of 2 UTStarcom XV6700 External Speaker Replacement: step 13, image 2 of 2
      • Press your finger on the speaker from the outside of the housing, and the speaker will come out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 50
All Time: 611
