UTStarcom CDM8945vw Logic Board Replacement
    1. UTStarcom CDM8945vw Logic Board Replacement, Battery: step 1, image 1 of 1
      • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
      Ask FixBot
    2. UTStarcom CDM8945vw Logic Board Replacement: step 2, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. UTStarcom CDM8945vw Logic Board Replacement, Antenna: step 3, image 1 of 1
      • Identify the antenna. It is the extendable plastic component pictured here.
      Ask FixBot
    2. UTStarcom CDM8945vw Logic Board Replacement: step 4, image 1 of 1
      • Twist the base in a counter-clockwise motion to unscrew the antenna.
      Ask FixBot
    3. UTStarcom CDM8945vw Logic Board Replacement: step 5, image 1 of 2 UTStarcom CDM8945vw Logic Board Replacement: step 5, image 2 of 2
      • The antenna should slide right out of the phone when finished.
      Ask FixBot
    1. UTStarcom CDM8945vw Logic Board Replacement, Speaker: step 6, image 1 of 1
      • Remove the small rubber grommet using the plastic opening tool.
      Ask FixBot
    2. UTStarcom CDM8945vw Logic Board Replacement: step 7, image 1 of 1
      • Remove five screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. UTStarcom CDM8945vw Logic Board Replacement: step 8, image 1 of 1
      • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
      • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
      Ask FixBot
    4. UTStarcom CDM8945vw Logic Board Replacement: step 9, image 1 of 1
      • Remove the back piece of the outer case.
      Ask FixBot
    5. UTStarcom CDM8945vw Logic Board Replacement: step 10, image 1 of 1
      • Remove the speaker using a plastic opening tool.
      • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
      Ask FixBot
    6. UTStarcom CDM8945vw Logic Board Replacement: step 11, image 1 of 2 UTStarcom CDM8945vw Logic Board Replacement: step 11, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the wire attached to the speaker from the motherboard using tweezers.
      • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
      Ask FixBot
    1. UTStarcom CDM8945vw Logic Board Replacement, Logic Board: step 12, image 1 of 1
      • Detach the highlighted piece from the logic board using a plastic opening tool.
      Ask FixBot
    2. UTStarcom CDM8945vw Logic Board Replacement: step 13, image 1 of 2 UTStarcom CDM8945vw Logic Board Replacement: step 13, image 2 of 2
      • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
      Ask FixBot
Bilal
1 Reputation
1 Guide authored
Cal Poly, Team 24-26, Regan Fall 2012 Member of Cal Poly, Team 24-26, Regan Fall 2012
CPSU-REGAN-F12S24G26
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 33
All Time: 656
