Up to 20% off select tools
USB/Auxiliary Port
Views: 16K
View statistics:
Past 24 Hours:
4
Past 7 Days:
30
Past 30 Days:
147
All Time:
16,379
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Better Introduction
Improve this guide by completing or revising its introduction.
USB/Auxiliary Port
Tools
    1. USB/Auxiliary Port, Outer Case: step 1, image 1 of 2 USB/Auxiliary Port, Outer Case: step 1, image 2 of 2
      • Using the standard metal spudger, begin by prying at the bottom of the plain rubber end cap (the end without the USB or auxiliary input).
      Ask FixBot
    2. USB/Auxiliary Port: step 2, image 1 of 1
      • Continue prying around the end panel, prying at different points until the entire panel is out of its seating.
      • Carefully remove the end panel.
      • The tabs which connect the panel are on the short sides.
      • WARNING: you will likely cause cosmetic damage to the end cap.
      Ask FixBot
    3. USB/Auxiliary Port: step 3, image 1 of 1
      • Slide out the rubber foot located on the bottom of the case.
      Ask FixBot
    4. USB/Auxiliary Port: step 4, image 1 of 1
      • Using a T6 bit, remove the flat topped 5mm screw located on the bottom of the casing, underneath the rubber foot.
      • This is the only flat topped screw in the speaker, so keep track of which one it is.
      Ask FixBot
    5. USB/Auxiliary Port: step 5, image 1 of 3 USB/Auxiliary Port: step 5, image 2 of 3 USB/Auxiliary Port: step 5, image 3 of 3
      • Push against the side without end cap to slide the internal components out of the case.
      • While holding the metal outset casing with one hand, press on the black inner plastic casing with your thumb.
      • It will be very difficult the first time. There is a rubber seal on the outside of the plastic inner case that creates a lot of friction with the metal outer case.
      Ask FixBot
    1. USB/Auxiliary Port, USB/Auxiliary Port: step 6, image 1 of 2 USB/Auxiliary Port, USB/Auxiliary Port: step 6, image 2 of 2
      • Using the standard metal spudger, carefully pry up the top 2 plastic tabs which hold the exterior button and port cover onto the interior plastic frame.
      Ask FixBot
    2. USB/Auxiliary Port: step 7, image 1 of 1
      • Using the classic metal spudger, pry up the bottom 2 tabs attaching the other side of the button panel.
      • It should come off after prying up the first tab.
      Ask FixBot
    3. USB/Auxiliary Port: step 8, image 1 of 3 USB/Auxiliary Port: step 8, image 2 of 3 USB/Auxiliary Port: step 8, image 3 of 3
      Tool used on this step:
      Buy
      • Carefully lift out the end panel.
      • Unplug both the connection ribbon and the ZIF ribbon using tweezers or your hands.
      • There is a bit of glue to hold the connection ribbon down.
      Ask FixBot
    4. USB/Auxiliary Port: step 9, image 1 of 1
      • Remove the 5mm T6 screw holding the port assembly onto the end cap.
      • Unlike the flat top screw holding the metal housing, these screws are roundtop.
      Ask FixBot
    5. USB/Auxiliary Port: step 10, image 1 of 1
      • Remove the old port assembly from the end cap.
      • Alternate Reassembly required, read on.
      Ask FixBot
    6. USB/Auxiliary Port: step 11, image 1 of 1
      • Disconnect the Motherboard connection ribbon from the motherboard.
      • The ribbon should no longer be connected at either end.
      Ask FixBot
    7. USB/Auxiliary Port: step 12, image 1 of 1
      • Very carefully pull the motherboard connection ribbon through the plastic casing, removing it from the plastic casing.
      Ask FixBot
    8. USB/Auxiliary Port: step 13, image 1 of 1
      • Insert the connection ribbon into its ZIF connection port on the bottom of the new port assembly
      • ZIF connectors are delicate and often give beginners trouble, search for ZIF connector tips on the web.
      Ask FixBot
    9. USB/Auxiliary Port: step 14, image 1 of 2 USB/Auxiliary Port: step 14, image 2 of 2
      • Position the new port assembly on the end cap and reinsert the 5mm T6 screw.
      • The rubber insulation around the motherboard connector should help hold the ZIF connector in place after the screw has been reinserted.
      Ask FixBot
    10. USB/Auxiliary Port: step 15, image 1 of 2 USB/Auxiliary Port: step 15, image 2 of 2
      • Reconnect the button ribbon connector on the top of the port assembly.
      Ask FixBot
    11. USB/Auxiliary Port: step 16, image 1 of 2 USB/Auxiliary Port: step 16, image 2 of 2
      • Reconnect the endcap to the plastic housing.
      • While you reconnect the endcap to the plastic housing, carefully position the ribbon slide through the ribbon slit and into the plastic casing.
      Ask FixBot
    12. USB/Auxiliary Port: step 17, image 1 of 1
      • Snap the end cap back onto the inner plastic casing and reconnect the ZIF ribbon to the motherboard.
      • Finish reassembling in descending order starting at step 5.
      Ask FixBot
To reassemble your device, follow steps 1 through 5 in reverse order.
5 other people completed this guide.
Author
with
Noah Sadler
560 Reputation
2 Guides authored
Cal Poly, Team 12-1, Lancaster Spring 2015 Member of Cal Poly, Team 12-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G1
5 Members
96 Guides authored
1 Guide Comment
Can anyone at all tell us where we can definitely purchase the USB/Auxiliary Port and its Motherboard to Aux Port ZIF Ribbon?
Thanks in advance.
barrysum - Reply Share
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 147
All Time: 16,379
