Up to 20% off select tools
USB Installation Media Creation (Rufus)
Views: 7.4K
View statistics:
Past 24 Hours:
16
Past 7 Days:
114
Past 30 Days:
479
All Time:
7,411
Comments: 2
2 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 25
25 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 2 hours
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Minimum flash drive size bump (as of 6/28/2026): I have increased the recommended minimum to 64GB. This is primarily due to Ubuntu's increasing ISO sizes and desire for the ISO size champion (e.g., 6.07GB for 26.04 LTS) and the fact that major retailers like Walmart have replaced 32GB name-brand stock with 64GB+ units. Furthermore, 32GB drives are now frequent targets for counterfeits and low-quality B-stock NAND that often fails during boot media creation. While 16-32GB drives remain technically viable for most other distros, 64GB+ is now the safest floor for new purchases.
If you need to write an ISO to a USB flash drive, this guide covers using Rufus. Because most modern computers lack optical drives, USB booting is the fastest way to install or run an operating system.
TL;DR: Buy a 64GB+ drive (USB 5Gbps, often listed as USB 3.0/3.1 or 3.2 Gen 1) preferred; USB 2.0 is slower but serviceable). IF BUDGET IS AN ISSUE, ERASE AND REUSE A PROVEN 16-32GB BRANDED DRIVE RATHER THAN BUYING NO-NAME JUNK!
Note on 8GB/16GB Drives: For mainstream OS installs, 8GB drives are effectively obsolete. While they remain viable for "minimalist" targeted uses—such as Arch Linux, Puppy Linux, Debian NetInst images or even full blown diagnostic tools like Parted Magic which still fit comfortably—they lack the capacity for the "standard" Linux desktop installers most people need as they do not have the margins for formatting, drivers, packages and Linux firmware. Unless you are specifically building a lightweight tool such as the examples in this guide where they still work, it's time to consider them too small for modern use. 16GB drives will still be viable for a few more years, but will eventually hit the same limits. 32GB drives are fine for now, but verify your source and test any "grey market" purchases.
AMAZON/eBay WARNING: If you buy the drive for this on Amazon or eBay and it has issues out of the box, it is probably counterfeit - get rid of it and buy another one in person. Test these with a tool like ValiDrive (GRC) or h2testw before you rely on these drives and send it back if it has problems.
Guide notes
    1. USB Installation Media Creation (Rufus), Why cheap drives are bad: step 1, image 1 of 1
      • I bought some cheap USB drives for a copy of PM 2020 for 32-bit PCs from walmart, even adjusting the clusters from 16>32, I still had issues.
      Ask FixBot
    2. USB Installation Media Creation (Rufus), Download Rufus: step 2, image 1 of 3 USB Installation Media Creation (Rufus), Download Rufus: step 2, image 2 of 3 USB Installation Media Creation (Rufus), Download Rufus: step 2, image 3 of 3
      • THIS PROCEDURE WILL ERASE THE TARGET USB DRIVE! BACKUP THE DRIVE OR USE A NEW ONE IF YOU DO NOT HAVE A DRIVE THAT CAN BE ERASED.
      • If you are reusing an old drive, format it first!
      • To write the ISO, download Rufus. Place this somewhere it is easily found.
      Ask FixBot
    3. USB Installation Media Creation (Rufus), Download your ISO: step 3, image 1 of 3 USB Installation Media Creation (Rufus), Download your ISO: step 3, image 2 of 3 USB Installation Media Creation (Rufus), Download your ISO: step 3, image 3 of 3
      • Authors note: While this guide is being demoed with Linux, it can be used with any bootable ISO - Linux ISOs, utilities like Parted Magic and more.
      • Torrent clients require additional configuration NOT COVERED in this guide. Some distros offer this option and you can use it but every torrent client is a little different.
      • After downloading Rufus, download the ISO you want to write to the USB drive. The file will be in the default download location you picked but is typically in the the Downloads folder.
      Ask FixBot
    4. USB Installation Media Creation (Rufus), Locate the ISO: step 4, image 1 of 3 USB Installation Media Creation (Rufus), Locate the ISO: step 4, image 2 of 3 USB Installation Media Creation (Rufus), Locate the ISO: step 4, image 3 of 3
      • Default download locations: Windows (Recent versions; 7 and newer): Downloads
      • Plug the USB drive in and select the ISO you want to use.
      Ask FixBot
    5. USB Installation Media Creation (Rufus), Writing the ISO file: step 5, image 1 of 3 USB Installation Media Creation (Rufus), Writing the ISO file: step 5, image 2 of 3 USB Installation Media Creation (Rufus), Writing the ISO file: step 5, image 3 of 3
      • If you are using a system with a buggy Legacy BIOS, consider adding "Add fixes for older BIOSes".
      • Open Rufus and click SELECT. Find the ISO and click Open.
      • Rufus will ask you to choose ISO or DD mode. If unsure, choose ISO mode.
      • After configuring the writing process, click start. Click OK on the formatting warning.
      Ask FixBot
Finish Line
15 other people completed this guide.
Author
with
Nick
107,133 Reputation
73 Guides authored
2 Guide Comments
Unetbootin does not work anymore and is considered unstable to use when installing any Linux OS, also 4GB USB drives are more than big enough to get the job done
Will - Reply Share
My reasoning for saying 8GB is because 4GB sticks are all but nonexistent (8GB is more popular now), but if you already own the 4GB stick then it'll work. I even use one from 2006 in the guide, to show that reuse is possible.
Oh really? I always thought it was still a usable option - thanks for letting me know that I was wrong.
Nick - Reply Share
Past 24 Hours: 16
Past 7 Days: 114
Past 30 Days: 479
All Time: 7,411
