URI Piccolos Set - Contact problems - Replace battery
Views: 1.7K
View statistics:
Past 24 Hours:
10
Past 7 Days:
33
Past 30 Days:
114
All Time:
1,704
Comments: 8
7 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
The popular table lamps sold as the “Remember URI Piccolos Set,” occasionally have contact problems with the battery. Repair is not difficult once the lamp has been opened.
    1. URI Piccolos Set - Contact problems - Replace battery, Open URI Piccolos Set: step 1, image 1 of 1
      • First, pull the carrying handle out of the holder with a firm tug.
      Ask FixBot
      • Also note the description in the comment!
      Ask FixBot
    1. URI Piccolos Set - Contact problems - Replace battery, Battery: step 3, image 1 of 1
      • I tried to open the bottom part. You can see the marks on the picture from my futile attempts to pry the bottom off.
      Ask FixBot
    2. URI Piccolos Set - Contact problems - Replace battery, The solution to the mystery: step 4, image 1 of 1
      • I pulled so hard on the cover that the retaining tabs gave way...
      • If you want to do it better: You may be able to reach the retaining tabs of the cover through the designated holes.
      • However, as there are four retaining tabs, you will probably need a special tool to unlock them all at the same time. I only realized this after using my somewhat brutal method.
      • This caused minor damage to the lower part, but this can be repaired with some plastic glue.
      Ask FixBot
    3. URI Piccolos Set - Contact problems - Replace battery: step 5, image 1 of 1
      • Finally, the lower part is open in front of us and you can resolve contact problems or even change the battery...
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
HolgerHa
213 Reputation
2 Guides authored
1 Guide Comment
Geht nicht. Schritt 3 ist völlig unverständlich. Was soll man wo machen ? Aber vielleicht ist diese Anleitung auch nur Teil eines Technik-Quiz.....
Frantoiano - Reply Share
Past 24 Hours: 10
Past 7 Days: 33
Past 30 Days: 114
All Time: 1,704
