ULCO ntegrus PSV ventilator Battery Replacement
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
    • Before disassembly, make sure the front wheel breaks are on.
    Ask FixBot
    • Make sure ALL gas supplies are disconnected and the system has been purged, and make sure all electrical supplies have been disconnected.
    Ask FixBot
  1. Ask FixBot
  2. ULCO ntegrus PSV ventilator Battery Replacement: step 4, image 1 of 1
    • With one hand on the ventilator removal handle and one holding the lower half of the ventilator, pull up firmly on the handle so that the mounting slides up the slots in the frame.
    Ask FixBot
  3. ULCO ntegrus PSV ventilator Battery Replacement: step 5, image 1 of 1
    • Pull the ventilator housing towards you so that the mounting tabs come out of the frame slots rest the ventilator housing on the plastic skirt at the rear of the workstation as shown in the photo.
    Ask FixBot
  4. ULCO ntegrus PSV ventilator Battery Replacement, Battery: step 6, image 1 of 1
    • Remove the main cover plate from the ventilator enclosure by removing all screws.
    Ask FixBot
    • Disconnect the battery.
    Ask FixBot
  5. ULCO ntegrus PSV ventilator Battery Replacement: step 8, image 1 of 1
    • Remove the four pan head screws (SM0308P) holding down the battery plate (EV9109) and battery (EV9108) and remove the battery plate and battery.
    Ask FixBot
  6. ULCO ntegrus PSV ventilator Battery Replacement: step 9, image 1 of 1
    • Install the new battery in the same location and screw down the battery plate onto the battery plate spacers so that the battery is firmly held in place.
    Ask FixBot
    • Reconnect the battery.
    Ask FixBot
Preston Myers
493 Reputation
4 Guides authored
Cal Poly, Team S7-G13, Paton Spring 2020 Member of Cal Poly, Team S7-G13, Paton Spring 2020
CPSU-PATON-S20S7G13
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 26
All Time: 182
