UE BOOM 2 Micro-USB Port Replacement
    1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: step 1, image 1 of 2 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: step 1, image 2 of 2
      • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
      • Remove by twisting in a counter-clockwise motion.
      Ask FixBot
    2. UE BOOM 2 Micro-USB Port Replacement: step 2, image 1 of 2 UE BOOM 2 Micro-USB Port Replacement: step 2, image 2 of 2
      • After the D-ring has been removed, the rubber port cover can be removed.
      Ask FixBot
    3. UE BOOM 2 Micro-USB Port Replacement: step 3, image 1 of 3 UE BOOM 2 Micro-USB Port Replacement: step 3, image 2 of 3 UE BOOM 2 Micro-USB Port Replacement: step 3, image 3 of 3
      • Remove the rubber stripping using a metal spudger.
      • Work around the edge of the rubber stripping slowly prying up the edge.
      Ask FixBot
    4. UE BOOM 2 Micro-USB Port Replacement: step 4, image 1 of 1
      • Continue removing the rubber stripping down the side.
      Ask FixBot
    5. UE BOOM 2 Micro-USB Port Replacement: step 5, image 1 of 3 UE BOOM 2 Micro-USB Port Replacement: step 5, image 2 of 3 UE BOOM 2 Micro-USB Port Replacement: step 5, image 3 of 3
      • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
      • Pry up at the location marked, and remove the plastic end cap.
      • The white plastic section houses the USB micro B, and must be replaced as a whole.
      Ask FixBot
9 other people completed this guide.
Alex Bahm
2,360 Reputation
6 Guides authored
Cal Poly, Team S12-G5, Banghart Winter 2018 Member of Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 Members
84 Guides authored
6 Guide Comments
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - Reply Share
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - Reply Share
i too am looking to find the replacement part
Liam Nicholls - Reply Share
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - Reply Share
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - Reply Share
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 129
All Time: 11,975
