Up to 20% off select tools
UDI U818A Propeller Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
85
All Time:
2,663
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
In this procedure we must take care to put the correct blades on the correct motor, because white propellers bend in one direction while black propellers are opposite.
    1. UDI U818A Propeller Replacement, Propellers: step 1, image 1 of 2 UDI U818A Propeller Replacement, Propellers: step 1, image 2 of 2
      • Remove the 5 mm screws connecting each propeller to the rotating post using a Phillips #000 screwdriver.
      • As each screw is removed, safely pull the respective propeller from its apparatus.
      Ask FixBot
Author
with
Anthony Mitchell
838 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 85
All Time: 2,663
