UDI U818A Drone Cover Replacement
  1. UDI U818A Drone Cover Replacement, Propellers: step 1, image 1 of 2 UDI U818A Drone Cover Replacement, Propellers: step 1, image 2 of 2
    • Remove the 5 mm screws connecting each propeller to the rotating post using a Phillips #000 screwdriver.
    • As each screw is removed, safely pull the respective propeller from its apparatus.
    Ask FixBot
  2. UDI U818A Drone Cover Replacement, Drone Cover: step 2, image 1 of 2 UDI U818A Drone Cover Replacement, Drone Cover: step 2, image 2 of 2
    • Remove four 3 mm screws connecting the electronics to the frame using a Phillips #000 screwdriver.
    • Pull the two LED bars through the dust cover and remove the thin plastic dust cover from the drone.
    • As the piece connecting the electronics to the drone cover are accessible, keep note to not remove electronics until after disconnecting the drone head lamp first.
    Ask FixBot
  3. UDI U818A Drone Cover Replacement: step 3, image 1 of 2 UDI U818A Drone Cover Replacement: step 3, image 2 of 2
    • Remove the single 5 mm screw from the head lamp using a Phillips #000 screwdriver.
    • Remove the head lamp from the rest of the drone.
    • Disconnect the electronics from the frame of the drone by pulling each arm out of the hole in the frame holding it in place.
    • Do not try to separate the frame from the electronics yet! Check to see if there is tape holding the head lamp wires in place underneath the electronics.
    Ask FixBot
  4. UDI U818A Drone Cover Replacement: step 4, image 1 of 3 UDI U818A Drone Cover Replacement: step 4, image 2 of 3 UDI U818A Drone Cover Replacement: step 4, image 3 of 3
    • If present, remove the white tape over the black and red wires on the head lamp with a spudger.
    • Keep the tape in reusable condition to re-secure the headlight later so there are no loose wires.
    • Separate the plastic tabs securing the motor arms to the drone cover and delicately pull out the arm. Do this for all four arms to remove the frame from the cover.
    Ask FixBot
3 other people completed this guide.
Anthony Mitchell
838 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 24
All Time: 1,603
