UDI U818A Drone Arms Replacement
  1. UDI U818A Drone Arms Replacement, Propellers: step 1, image 1 of 2 UDI U818A Drone Arms Replacement, Propellers: step 1, image 2 of 2
    • Remove the 5 mm screws connecting each propeller to the rotating post using a Phillips #000 screwdriver.
    • As each screw is removed, safely pull the respective propeller from its apparatus.
    Ask FixBot
  2. UDI U818A Drone Arms Replacement, Drone Cover: step 2, image 1 of 2 UDI U818A Drone Arms Replacement, Drone Cover: step 2, image 2 of 2
    • Remove four 3 mm screws connecting the electronics to the frame using a Phillips #000 screwdriver.
    • Pull the two LED bars through the dust cover and remove the thin plastic dust cover from the drone.
    • As the piece connecting the electronics to the drone cover are accessible, keep note to not remove electronics until after disconnecting the drone head lamp first.
    Ask FixBot
  3. UDI U818A Drone Arms Replacement: step 3, image 1 of 2 UDI U818A Drone Arms Replacement: step 3, image 2 of 2
    • Remove the single 5 mm screw from the head lamp using a Phillips #000 screwdriver.
    • Remove the head lamp from the rest of the drone.
    • Disconnect the electronics from the frame of the drone by pulling each arm out of the hole in the frame holding it in place.
    • Do not try to separate the frame from the electronics yet! Check to see if there is tape holding the head lamp wires in place underneath the electronics.
    Ask FixBot
  4. UDI U818A Drone Arms Replacement: step 4, image 1 of 3 UDI U818A Drone Arms Replacement: step 4, image 2 of 3 UDI U818A Drone Arms Replacement: step 4, image 3 of 3
    • If present, remove the white tape over the black and red wires on the head lamp with a spudger.
    • Keep the tape in reusable condition to re-secure the headlight later so there are no loose wires.
    • Separate the plastic tabs securing the motor arms to the drone cover and delicately pull out the arm. Do this for all four arms to remove the frame from the cover.
    Ask FixBot
  5. UDI U818A Drone Arms Replacement, Drone Arms: step 5, image 1 of 1
    • Remove four 5 mm corner screws that secure both the receiving board and the motor arm using a Phillips #000 screwdriver.
    • When reassembling, notice how the wires tuck neatly in the bottom channel of the motor arm.
    Ask FixBot
  6. UDI U818A Drone Arms Replacement: step 6, image 1 of 3 UDI U818A Drone Arms Replacement: step 6, image 2 of 3 UDI U818A Drone Arms Replacement: step 6, image 3 of 3
    • Carefully slide the arm out from the socket.
    • Use a nylon spudger to remove the connectors from the receiving board.
    • The cables connecting to the receiving board will be secured with a light adhesive that can be easily scraped away to remove the desired connector.
    Ask FixBot
  7. UDI U818A Drone Arms Replacement: step 7, image 1 of 2 UDI U818A Drone Arms Replacement: step 7, image 2 of 2
    • Motor direction and propeller direction is crucial to proper flight. Refer to this format when reassembling.
    • The Front Left motor identified by the Red/Blue wires is a Standard(Clockwise) spinning motor, it pairs with a White A2 propeller.
    • The Front Right motor identified by the Black/White wires is a Reverse(CounterClockwise) spinning motor, it pairs with a White B2 propeller.
    • The Back Left motor identified by the Black/White wires is a Reverse(CounterClockwise) spinning motor, it pairs with a Black B1 propeller.
    • The Back Right motor identified by the Red/Blue wires is a Standard(Clockwise) spinning motor, it pairs with a Black A1 propeller.
    Ask FixBot
  8. UDI U818A Drone Arms Replacement: step 8, image 1 of 1
    • The wiring can appear confusing, don't be alarmed. It's quite easy, and absolutely necessary for proper flight.
    • The 4 bottom connectors receive the motor power cables that are Red/Yellow wire pairs from each motor. Counting the sockets 1-4 from left to right.
    • Front Right motor connects to socket 1.
    • Front Left motor connects to socket 2.
    • Rear Left motor connects to socket 3.
    • Rear Right motor connects to socket 4.
    • The Red/Green wire pairs from each motor power the LED to that branch, they connect to 4 of 6 sockets on the top of the receiving board. There is no sequence required.
    • The headlight LED, and underside LED bars connect to the remaining 2 sockets on the top of the receiving board. Again, no sequence is required. All LED Red/Black and Red/Green wire pairs connect to top of the receiving board.
    Ask FixBot
5 other people completed this guide.
Anthony Mitchell
838 Reputation
5 Guides authored
5 Guide Comments
Very helpful, thanks!
Cam F - Reply Share
One of my prop motors stopped so I replaced the arm as described above but when I plug in the battery the prop spins. Then when I turn on the controller and calibrate it stops spinning and the other props spin
Fran Herman - Reply Share
Same problem here, Fran. How'd you solve it?
Tom Hallman - Reply Share
Same issue as above. just replaces the front right arm/engine. When reconnecting, the replacement arms spins as soon as the battery is connected. Only way to stop it is to unplug it. Tried plugging other original arms into in and they do the same? Is this a mother board issue instead?
DaveDaughe - Reply Share
Same as above. Replace and arm/engine. When I plug it in, it spins constantly, unless I unplug the battery. Plug one of the other original arms into in and they do the same. Assuming this is now a mother board issue vs an arm/engine issue?
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 37
All Time: 6,101
