U-Turn Audio Orbit Drive Belt Replacement
  1. U-Turn Audio Orbit Drive Belt Replacement, Drive Belt: step 1, image 1 of 1
    • Using your left hand, hold the belt in the groove located in the pulley in the upper left hand corner of the turntable.
    Ask FixBot
  2. U-Turn Audio Orbit Drive Belt Replacement: step 2, image 1 of 1
    • Use your right hand to hold the belt against the outer edge of the platter at roughly the 12 o'clock position.
    Ask FixBot
  3. U-Turn Audio Orbit Drive Belt Replacement: step 3, image 1 of 1
    • Rotate the platter to begin wrapping the belt.
    • As you rotate, let the belt slide between your left hand and the pulley notch to easily pull the belt through the pulley.
    Ask FixBot
  4. U-Turn Audio Orbit Drive Belt Replacement: step 4, image 1 of 1
    • Continue to rotate the platter while still holding the belt in place with your left until the belt is fully wrapped around the platter.
    • Avoid pulling the pulley or the belt to the right which will lead to excess slack and may cause the belt to fall off the platter.
    Ask FixBot
  5. U-Turn Audio Orbit Drive Belt Replacement: step 5, image 1 of 1
    • Once the belt is secured along the entire circumference of the platter, the replacement is complete, and the turnable is once more operational.
    Ask FixBot
Finish Line
Luc Maho
121 Reputation
1 Guide authored
UC Davis, Team 1-2, Whithaus Spring 2025 Member of UC Davis, Team 1-2, Whithaus Spring 2025
UCD-WHITHAUS-S25S1G2
4 Members
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 74
All Time: 706
