Turtle Beach Stealth Ultra Option Buttons Replacement
    1. Turtle Beach Stealth Ultra Option Buttons Replacement, Back Plate: step 1, image 1 of 2 Turtle Beach Stealth Ultra Option Buttons Replacement, Back Plate: step 1, image 2 of 2
      • Use tweezers to pull out rubber pieces in front of the screws.
      Ask FixBot
    2. Turtle Beach Stealth Ultra Option Buttons Replacement: step 2, image 1 of 2 Turtle Beach Stealth Ultra Option Buttons Replacement: step 2, image 2 of 2
      • Remove the 10 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. Turtle Beach Stealth Ultra Option Buttons Replacement: step 3, image 1 of 2 Turtle Beach Stealth Ultra Option Buttons Replacement: step 3, image 2 of 2
      • Remove the sticker on the back of the plate.
      • Remove the 10 mm screws from the back plate using a Phillips #00 screwdriver.
      Ask FixBot
    4. Turtle Beach Stealth Ultra Option Buttons Replacement: step 4, image 1 of 3 Turtle Beach Stealth Ultra Option Buttons Replacement: step 4, image 2 of 3 Turtle Beach Stealth Ultra Option Buttons Replacement: step 4, image 3 of 3
      • Use an iFixit opening tool to pry the front button plate and analog stick plate off.
      • Use a Phillips #00 screwdriver to remove the screws from the front plate on both sides of the controller.
      • Be cautious not to break the LCD screen while you move the opening tool around.
      Ask FixBot
    5. Turtle Beach Stealth Ultra Option Buttons Replacement: step 5, image 1 of 3 Turtle Beach Stealth Ultra Option Buttons Replacement: step 5, image 2 of 3 Turtle Beach Stealth Ultra Option Buttons Replacement: step 5, image 3 of 3
      • Use an opening tool to detach the front plate from the back.
      • You may need to work the opening tool all the way around the seam between the two plates.
      Ask FixBot
    1. Turtle Beach Stealth Ultra Option Buttons Replacement, Motherboard: step 6, image 1 of 2 Turtle Beach Stealth Ultra Option Buttons Replacement, Motherboard: step 6, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the 10 mm screws connecting the handles to the controller frame.
      Ask FixBot
    2. Turtle Beach Stealth Ultra Option Buttons Replacement: step 7, image 1 of 1
      • Detach the cables from the motherboard.
      Ask FixBot
    3. Turtle Beach Stealth Ultra Option Buttons Replacement: step 8, image 1 of 1
      • Remove the yellow ribbon cable from the handle.
      Ask FixBot
    4. Turtle Beach Stealth Ultra Option Buttons Replacement: step 9, image 1 of 2 Turtle Beach Stealth Ultra Option Buttons Replacement: step 9, image 2 of 2
      • Remove the six 10 mm screws connected to the motherboard using a Phillips #00 screwdriver.
      Ask FixBot
    5. Turtle Beach Stealth Ultra Option Buttons Replacement: step 10, image 1 of 1
      • Gently pull the motherboard away from the frame.
      Ask FixBot
    1. Turtle Beach Stealth Ultra Option Buttons Replacement, Option Buttons: step 11, image 1 of 3 Turtle Beach Stealth Ultra Option Buttons Replacement, Option Buttons: step 11, image 2 of 3 Turtle Beach Stealth Ultra Option Buttons Replacement, Option Buttons: step 11, image 3 of 3
      • Use the spudger to pry the option buttons out from the front plate.
      Ask FixBot
2 other people completed this guide.
Dominic Dodge
856 Reputation
7 Guides authored
1 Guide Comment
Bon tutoriel merci.!
REGIS-EYMARD - Reply Share
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 76
All Time: 484
