Turtle Beach Stealth Ultra Motherboard Replacement
  1. Turtle Beach Stealth Ultra Motherboard Replacement, Back Plate: step 1, image 1 of 2 Turtle Beach Stealth Ultra Motherboard Replacement, Back Plate: step 1, image 2 of 2
    • Use tweezers to pull out rubber pieces in front of the screws.
    Ask FixBot
  2. Turtle Beach Stealth Ultra Motherboard Replacement: step 2, image 1 of 2 Turtle Beach Stealth Ultra Motherboard Replacement: step 2, image 2 of 2
    • Remove the 10 mm screws using a Phillips #00 screwdriver.
    Ask FixBot
  3. Turtle Beach Stealth Ultra Motherboard Replacement: step 3, image 1 of 2 Turtle Beach Stealth Ultra Motherboard Replacement: step 3, image 2 of 2
    • Remove the sticker on the back of the plate.
    • Remove the 10 mm screws from the back plate using a Phillips #00 screwdriver.
    Ask FixBot
  4. Turtle Beach Stealth Ultra Motherboard Replacement: step 4, image 1 of 3 Turtle Beach Stealth Ultra Motherboard Replacement: step 4, image 2 of 3 Turtle Beach Stealth Ultra Motherboard Replacement: step 4, image 3 of 3
    • Use an iFixit opening tool to pry the front button plate and analog stick plate off.
    • Use a Phillips #00 screwdriver to remove the screws from the front plate on both sides of the controller.
    • Be cautious not to break the LCD screen while you move the opening tool around.
    Ask FixBot
  5. Turtle Beach Stealth Ultra Motherboard Replacement: step 5, image 1 of 3 Turtle Beach Stealth Ultra Motherboard Replacement: step 5, image 2 of 3 Turtle Beach Stealth Ultra Motherboard Replacement: step 5, image 3 of 3
    • Use an opening tool to detach the front plate from the back.
    • You may need to work the opening tool all the way around the seam between the two plates.
    Ask FixBot
  6. Turtle Beach Stealth Ultra Motherboard Replacement, Motherboard: step 6, image 1 of 2 Turtle Beach Stealth Ultra Motherboard Replacement, Motherboard: step 6, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the 10 mm screws connecting the handles to the controller frame.
    Ask FixBot
  7. Turtle Beach Stealth Ultra Motherboard Replacement: step 7, image 1 of 1
    • Detach the cables from the motherboard.
    Ask FixBot
  8. Turtle Beach Stealth Ultra Motherboard Replacement: step 8, image 1 of 1
    • Remove the yellow ribbon cable from the handle.
    Ask FixBot
  9. Turtle Beach Stealth Ultra Motherboard Replacement: step 9, image 1 of 2 Turtle Beach Stealth Ultra Motherboard Replacement: step 9, image 2 of 2
    • Remove the six 10 mm screws connected to the motherboard using a Phillips #00 screwdriver.
    Ask FixBot
  10. Turtle Beach Stealth Ultra Motherboard Replacement: step 10, image 1 of 1
    • Gently pull the motherboard away from the frame.
    Ask FixBot
Dominic Dodge
814 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 68
All Time: 337
