Introduction
The battery in the Turtle Beach Stealth Ultra controller (model number TBS-0710-05) is responsible for holding the controller's charge and allowing users to play wirelessly. In order to replace it, you first need to disassemble the controller. As you do, be cautious not to damage the screen or motherboard. Follow these steps to fix it.
Additional Resources:
Stealth Ultra Controller Support Site
Video on Turtle Beach Stealth Ultra Disassembly and Reassembly
Use a Phillips #00 screwdriver to remove the 10 mm screws connecting the handles to the controller frame.
Use the Phillips #00 screwdriver to remove the 10 mm screws from the black battery bracket.
Pull the battery bracket off of the battery.
Detach the cable connector from the motherboard.
