Turtle Beach Stealth Ultra Back Plate Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
84
All Time:
512
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
In order to replace anything in your Turtle Beach Stealth Ultra controller (model number TBS-0710-05), you first need to detach the backplate from the front plate. The back plate is responsible for keeping the internal parts of the controller protected. While following this guide, be cautious not to damage the LCD screen or motherboard. Follow these steps to remove the back plate.
Additional Resources:
Stealth Ultra Controller Support Site
Video on Turtle Beach Stealth Ultra Disassembly and Reassembly
Tools
    1. Turtle Beach Stealth Ultra Back Plate Replacement, Back Plate: step 1, image 1 of 2 Turtle Beach Stealth Ultra Back Plate Replacement, Back Plate: step 1, image 2 of 2
      • Use tweezers to pull out rubber pieces in front of the screws.
      Ask FixBot
    2. Turtle Beach Stealth Ultra Back Plate Replacement: step 2, image 1 of 2 Turtle Beach Stealth Ultra Back Plate Replacement: step 2, image 2 of 2
      • Remove the 10 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. Turtle Beach Stealth Ultra Back Plate Replacement: step 3, image 1 of 2 Turtle Beach Stealth Ultra Back Plate Replacement: step 3, image 2 of 2
      • Remove the sticker on the back of the plate.
      • Remove the 10 mm screws from the back plate using a Phillips #00 screwdriver.
      Ask FixBot
    4. Turtle Beach Stealth Ultra Back Plate Replacement: step 4, image 1 of 3 Turtle Beach Stealth Ultra Back Plate Replacement: step 4, image 2 of 3 Turtle Beach Stealth Ultra Back Plate Replacement: step 4, image 3 of 3
      • Use an iFixit opening tool to pry the front button plate and analog stick plate off.
      • Use a Phillips #00 screwdriver to remove the screws from the front plate on both sides of the controller.
      • Be cautious not to break the LCD screen while you move the opening tool around.
      Ask FixBot
    5. Turtle Beach Stealth Ultra Back Plate Replacement: step 5, image 1 of 3 Turtle Beach Stealth Ultra Back Plate Replacement: step 5, image 2 of 3 Turtle Beach Stealth Ultra Back Plate Replacement: step 5, image 3 of 3
      • Use an opening tool to detach the front plate from the back.
      • You may need to work the opening tool all the way around the seam between the two plates.
      Ask FixBot
Dominic Dodge
856 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 84
All Time: 512
