Introduction
This guide will demonstrate removing the motherboard from your Turtle Beach Recon.
The motherboard connects all of the components within your Turtle Beach Recon by distributing electricity. Ensure that your Turtle Beach Recon is unplugged and separated from your power source.
Removing the motherboard is often necessary if your Turtle Beach Recon is not responding, has been exposed to water, or has distorted audio.
Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
Use your fingers to lift both of the joystick caps off of the motherboard.
Remove the joystick caps.
Nothing can be further removed from the motherboard. It can now be replaced.
2 other people completed this guide.
