Up to 20% off select tools
Turtle Beach Recon Controller Front Buttons Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
105
All Time:
1,040
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes - 2 hours
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide demonstrates how to remove and replace the front buttons of your Turtle Beach Recon.
The front buttons are responsible for the majority of the input from your Turtle Beach Recon. The front buttons include functions of movement, menu, and power.
It is often necessary to remove and replace the front buttons should they be faulty, visibly broken, or dirty.
    1. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: step 1, image 1 of 3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: step 1, image 2 of 3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: step 1, image 3 of 3
      • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
      • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
      Ask FixBot
    2. Turtle Beach Recon Controller Front Buttons Replacement: step 2, image 1 of 3 Turtle Beach Recon Controller Front Buttons Replacement: step 2, image 2 of 3 Turtle Beach Recon Controller Front Buttons Replacement: step 2, image 3 of 3
      • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
      • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
      Ask FixBot
    1. Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: step 3, image 1 of 2 Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: step 3, image 2 of 2
      • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
      Ask FixBot
    2. Turtle Beach Recon Controller Front Buttons Replacement: step 4, image 1 of 2 Turtle Beach Recon Controller Front Buttons Replacement: step 4, image 2 of 2
      • Use your fingers to grab the motherboard.
      • Gently pull the motherboard and joystick caps away from the face plate.
      Ask FixBot
    3. Turtle Beach Recon Controller Front Buttons Replacement: step 5, image 1 of 3 Turtle Beach Recon Controller Front Buttons Replacement: step 5, image 2 of 3 Turtle Beach Recon Controller Front Buttons Replacement: step 5, image 3 of 3
      • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
      Ask FixBot
    1. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: step 6, image 1 of 3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: step 6, image 2 of 3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: step 6, image 3 of 3
      • Gently remove front buttons from the face plate by hand.
      Ask FixBot
2 other people completed this guide.
Author
with
Mary Goodrow
716 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 105
All Time: 1,040
