Introduction
Go to step 1 ↓This guide will demonstrate how to remove and replace the face plate of your Turtle Beach Recon.
The face plate supports the front components of your Turtle Beach Recon, including the front buttons and joystick caps. If it appears to be broken or exposed to water, it may need to be removed or replaced.
Tools
Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
