Up to 20% off select tools
Turtle Beach Recon Controller Back Plate Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
71
All Time:
1,420
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace the back plate on your Turtle Beach Recon.
The back plate supports the inside components of your Turtle Beach Recon such as the motherboard. It is often necessary to remove or replace the back plate should it appear to be broken or exposed to water.
    1. Turtle Beach Recon Controller Back Plate Replacement, Back Plate: step 1, image 1 of 3 Turtle Beach Recon Controller Back Plate Replacement, Back Plate: step 1, image 2 of 3 Turtle Beach Recon Controller Back Plate Replacement, Back Plate: step 1, image 3 of 3
      • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
      • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
      Ask FixBot
    2. Turtle Beach Recon Controller Back Plate Replacement: step 2, image 1 of 3 Turtle Beach Recon Controller Back Plate Replacement: step 2, image 2 of 3 Turtle Beach Recon Controller Back Plate Replacement: step 2, image 3 of 3
      • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
      • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
      Ask FixBot
3 other people completed this guide.
Author
with
Mary Goodrow
716 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 71
All Time: 1,420
