Turtle Beach Recon Cloud Bumpers Replacement
  1. Turtle Beach Recon Cloud Bumpers Replacement, Back Casing: step 1, image 1 of 2 Turtle Beach Recon Cloud Bumpers Replacement, Back Casing: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove 7 screws from the back casing.
    • The 2 inner screws are hidden under the Turtle Beach sticker.
    • The two screws at the bottom of the grips are countersunk, so you may need a 1/4" extender if your driver doesn’t fit.
    Ask FixBot
  2. Turtle Beach Recon Cloud Bumpers Replacement: step 2, image 1 of 2 Turtle Beach Recon Cloud Bumpers Replacement: step 2, image 2 of 2
    • Use the iFixit opening tool to wedge it between the inner grip and the casing to pry it off.
    • Do the same to the other inner grip.
    • Do not take off the outer grips as they have wiring attached to them.
    Ask FixBot
  3. Turtle Beach Recon Cloud Bumpers Replacement: step 3, image 1 of 2 Turtle Beach Recon Cloud Bumpers Replacement: step 3, image 2 of 2
    • Lift off the back casing.
    Ask FixBot
  4. Turtle Beach Recon Cloud Bumpers Replacement, Battery: step 4, image 1 of 3 Turtle Beach Recon Cloud Bumpers Replacement, Battery: step 4, image 2 of 3 Turtle Beach Recon Cloud Bumpers Replacement, Battery: step 4, image 3 of 3
    • Insert a spudger between the controller and the battery pack.
    • Use the spudger to loosen the battery from the motherboard.
    • Gently lift the battery pack until just out so as to not pull on the wire attached.
    Ask FixBot
  5. Turtle Beach Recon Cloud Bumpers Replacement: step 5, image 1 of 1
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • Don't pull on the wires as this can potentially damage the socket and device.
    Ask FixBot
  6. Turtle Beach Recon Cloud Bumpers Replacement, Top Case: step 6, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four screws securing the board.
    Ask FixBot
  7. Turtle Beach Recon Cloud Bumpers Replacement: step 7, image 1 of 2 Turtle Beach Recon Cloud Bumpers Replacement: step 7, image 2 of 2
    • Lift out the motherboard at an angle to detach it from the clips securing it to the case.
    • Don't lift the motherboard roughly or pull on it. There is a ribbon cable attached to the motherboard and front case.
    • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector—this is the unlocked position.
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    Ask FixBot
  8. Turtle Beach Recon Cloud Bumpers Replacement, Bumpers: step 8, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the two screws above the D-pad.
    Ask FixBot
  9. Turtle Beach Recon Cloud Bumpers Replacement: step 9, image 1 of 2 Turtle Beach Recon Cloud Bumpers Replacement: step 9, image 2 of 2
    • Remove the bumpers from the motherboard.
    • The bumpers are connected to a plastic bridge and should be removed as one piece.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 18
All Time: 106
