Up to 20% off select tools
Turtle Beach REACT-R Motherboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
76
All Time:
879
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The motherboard is the heart of the controller, housing the essential circuits that power every function. If you're facing issues like frequent disconnections, unresponsive buttons, or other hardware malfunctions, replacing the motherboard could be the solution. Follow these steps to safely and effectively replace the motherboard and get your controller back in top condition. For this procedure, you'll need a Phillips #00 screwdriver.
    1. Turtle Beach REACT-R Motherboard Replacement, Rear Case: step 1, image 1 of 3 Turtle Beach REACT-R Motherboard Replacement, Rear Case: step 1, image 2 of 3 Turtle Beach REACT-R Motherboard Replacement, Rear Case: step 1, image 3 of 3
      • Place the controller face down.
      • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
      • Use both hands to lift the backplate away from the controller.
      Ask FixBot
    1. Turtle Beach REACT-R Motherboard Replacement, Motherboard: step 2, image 1 of 3 Turtle Beach REACT-R Motherboard Replacement, Motherboard: step 2, image 2 of 3 Turtle Beach REACT-R Motherboard Replacement, Motherboard: step 2, image 3 of 3
      • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
      • Two of the screws are hidden under the red and black vibration motor wires.
      • Gently lift the motherboard up and out of the chassis.
      • Be careful not to strain the vibration motor wires.
      Ask FixBot
Author
with
Dodi Imam
697 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 76
All Time: 879
