Turtle Beach Ear Force XO One Adapter Buttons Replacement
    1. Turtle Beach Ear Force XO One Adapter Buttons Replacement, Adapter Buttons: step 1, image 1 of 1
      • Using a Philips head screwdriver, unscrew the two screws on the back of the adapter.
      • The recommended screwdriver bit size is a PH 000.
      Ask FixBot
    2. Turtle Beach Ear Force XO One Adapter Buttons Replacement: step 2, image 1 of 1
      • Using your hands and/or a prying tool, carefully pry open the adapter.
      • This step may require a bit of force to complete.
      • Be aware that the adapter is held together with clips on the inside at some locations.
      • Do not be alarmed if it makes a snapping sound as it comes apart, this is most likely just the sound of the clips detaching.
      Ask FixBot
    3. Turtle Beach Ear Force XO One Adapter Buttons Replacement: step 3, image 1 of 3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: step 3, image 2 of 3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: step 3, image 3 of 3
      • Now, using the same Philips head screwdriver, unscrew the two screws on either side that hold the circuit board to the adapter case.
      • Once the screws are out, you can remove the circuit board from the casing.
      Ask FixBot
    4. Turtle Beach Ear Force XO One Adapter Buttons Replacement: step 4, image 1 of 1
      • Push the rubber piece containing the buttons out of the plastic adapter casing.
      • Then, replace it with a new one.
      Ask FixBot
Joseph Lane
128 Reputation
1 Guide authored
UMass Dartmouth, Team 3-1, Shastany Fall 2015 Member of UMass Dartmouth, Team 3-1, Shastany Fall 2015
UMASSD-SHASTANY-F15S3G1
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 16
All Time: 1,874
