Turtle Beach Ear Force Stealth 500P Battery Replacement
  1. Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: step 1, image 1 of 3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: step 1, image 2 of 3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: step 1, image 3 of 3
    • Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
    • Work circularly until removed.
    Ask FixBot
  2. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 2, image 1 of 2 Turtle Beach Ear Force Stealth 500P Battery Replacement: step 2, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the four fastening screws that hold the blue plastic speaker mount in place.
    • Gently pull blue plastic from black housing by hand until separated.
    Ask FixBot
  3. Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: step 3, image 1 of 3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: step 3, image 2 of 3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: step 3, image 3 of 3
    • Use screwdriver tip J00 to remove three screws fastening circuit board to casing.
    Ask FixBot
  4. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 4, image 1 of 2 Turtle Beach Ear Force Stealth 500P Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use bent tweezers to remove two wire connector plugs from circuit board.
    Ask FixBot
  5. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 5, image 1 of 2 Turtle Beach Ear Force Stealth 500P Battery Replacement: step 5, image 2 of 2
    • Circuit board will be free to be removed by hand. Use plastic pry tool to slide between casing and circuit board if needed.
    Ask FixBot
  6. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 6, image 1 of 1
    • Gently removed and flip over circuit board to reveal battery pack attached to the underside. Careful not to pull out wires running through headband.
    Ask FixBot
  7. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 7, image 1 of 1
    • Use metal pry tool to slide between battery and circuit board to break up adhesive. Ensure the battery wire connector plug has been removed on front side.
    Ask FixBot
  8. Turtle Beach Ear Force Stealth 500P Battery Replacement: step 8, image 1 of 1
    • Battery will be free to be removed and replaced.
    Ask FixBot
11 other people completed this guide.
Noah Franklin
451 Reputation
5 Guides authored
UMass Dartmouth, Team 2-3, Shastany Fall 2015 Member of UMass Dartmouth, Team 2-3, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G3
3 Members
10 Guides authored
3 Guide Comments
Where can I get a replacement battery?
Jeremy Nocek - Reply Share
You can look on Ebay or Amazon. You can find it by searching the model number: ( FT603048P )
The costs are like $20-$30.
If you look on Ebay under: ( 3.7v 603048 ), you can get the same battery without the connector for like $5.
William Smith - Reply Share
hey i have a question, how i can repair the mute button? It does not work.
fiercecesar - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 74
All Time: 25,251
