Turtle Beach Ear Force P11 Speakers Replacement
  1. Turtle Beach Ear Force P11 Speakers Replacement, Ear Cushion: step 1, image 1 of 1
    • Pinch the inner edge of the ear cushion from the bottom.
    Ask FixBot
  2. Turtle Beach Ear Force P11 Speakers Replacement: step 2, image 1 of 1
    • Now slowly pull down the ear cushion as it completely separates from the speaker.
    • Carry out the pulling down action as slowly as possible or you might risk tearing the ear cushion otherwise
    Ask FixBot
  3. Turtle Beach Ear Force P11 Speakers Replacement, Speakers: step 3, image 1 of 1
    • Remove the 4 screws on the red speaker cover.
    • It is recommended to use a #000 Philips Screw Driver
    Ask FixBot
  4. Turtle Beach Ear Force P11 Speakers Replacement: step 4, image 1 of 2 Turtle Beach Ear Force P11 Speakers Replacement: step 4, image 2 of 2
    • Inspect the wires for damage as illustrated
    Ask FixBot
  5. Turtle Beach Ear Force P11 Speakers Replacement: step 5, image 1 of 1
    • De-solder the speaker wires and remove the speaker.
    • Use low heat for de - soldering
    Ask FixBot
  6. Turtle Beach Ear Force P11 Speakers Replacement: step 6, image 1 of 1
    • Solder the new speaker wires in the same position as the old one.
    • It is advisable to use a lead free solder
    • Use a small amount of solder to not mix up the connections and prevent short circuiting.
    • In case you use a large amount of solder, use a solder wick to absorb the excess solder.
    • You can find more information on "How To Solder" here:How To Solder and Desolder Connections
    Ask FixBot
4 other people completed this guide.
Bhavesh Gandhi
597 Reputation
3 Guides authored
IUPUI, Team 1-2, Wilson Fall 2015 Member of IUPUI, Team 1-2, Wilson Fall 2015
IUPUI-WILSON-F15S1G2
2 Members
6 Guides authored
6 Guide Comments
can you fix mine contact me a jtrent238@outlook.com
jtrent238 - Reply Share
I am sorry jtrent238 , but i can further guide you on how you could solve the problem
Bhavesh Gandhi - Reply Share
If you look at step four you will see the black wire has a knot and a silver metal part. Well My wire has broken right there any advice? Please help!
Dev - Reply Share
Do you know where I can get the speakers from?
James Patrick - Reply Share
my problem exist in this area https://imgur.com/grLwOkt cant figure out how to detach the entire bud to get access to the internal wires
John - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 45
All Time: 4,173
