Tungsten T3 Motherboard Replacement
    1. Tungsten T3 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • To remove the cover press down on the center indentation and remove from device.
      • If you have a memory card inserted into your device make sure to remove it.
      Ask FixBot
    2. Tungsten T3 Motherboard Replacement: step 2, image 1 of 1
      • There will be a set of 2 screws located on each side of your device. Remove these by using a Phillips head screwdriver.
      Ask FixBot
    3. Tungsten T3 Motherboard Replacement: step 3, image 1 of 1
      • The arrows in the picture indicate two small holes located at the top of the device. Insert a paper clip or a tack simultaneously into each of these holes and moderately push downward to remove the backing.
      • The springs will give as pressure is exerted. Once you feel this take place, pull down the cover with the paper clip/tack while continuing to push downward. This will release the back cover.
      Ask FixBot
    4. Tungsten T3 Motherboard Replacement: step 4, image 1 of 1
      • The buttons and sliding tray will be connected to the main body by a orange cable. You can separate the two components by gently peeling the cable off of the main body. You can remove this by gently lifting up.
      • Make sure the cable is still connected to the buttons and sliding tray.
      • Set aside the buttons and slide tray, making sure the orange cable is with it.
      Ask FixBot
    5. Tungsten T3 Motherboard Replacement: step 5, image 1 of 1
      • The arrows indicate two small screws. Using a Phillips head screwdriver, remove them.
      Ask FixBot
    6. Tungsten T3 Motherboard Replacement: step 6, image 1 of 1
      • To open the device, the sides must be (with moderate force) pried apart using a prying tool as seen in the picture.
      • Both sides must be separated from one another.
      • Tip: The right side may be slightly more difficult. It will be easiest to begin on the left.
      • Beginning with the left side, gently pry at the division of the face plates until they separate from one another.
      • Repeat this process on the other side of the device.
      Ask FixBot
    7. Tungsten T3 Motherboard Replacement: step 7, image 1 of 1
      • Hint: There will be pressure points along the side (as seen in the picture). Exerting pressure in these points will allow the sides to separate more easily.
      Ask FixBot
    8. Tungsten T3 Motherboard Replacement: step 8, image 1 of 1
      • Remove the face plate and set aside. This will leave the core of the device in front of you.
      • The core of the device will be connected by various cables. Gently lift the screen and mother board (as in picture).
      • As labeled in the picture, the orange screen cable will connect on the lower right side of the motherboard.
      • Disconnect the cable by pulling it upward from the motherboard connection. Depending on your device, it may require little to moderate force.
      • Carefully remove your screen.
      Ask FixBot
    9. Tungsten T3 Motherboard Replacement: step 9, image 1 of 1
      • The battery connects to the motherboard (as seen in picture) by red and black cables.
      • Be gentle when disconnecting. The wires will be tightly fitted; however, it is very important the connection is not broken in the port.
      • Gently pull out battery wire connection.
      Ask FixBot
    10. Tungsten T3 Motherboard Replacement: step 10, image 1 of 1
      • At this step the Motherboard control panel will be completely disconnected from your Tungsten T3 Device.
      • Replace the old control panel with the new Motherboard.
      Ask FixBot
    11. Tungsten T3 Motherboard Replacement: step 11, image 1 of 1
      • The new Motherboard reconnects to the battery through the same connection as shown in picture.
      • Once connected, place the new Motherboard control panel.
      Ask FixBot
    12. Tungsten T3 Motherboard Replacement: step 12, image 1 of 1
      • Next, the screen must be reconnected to the motherboard.
      • Connect the new orange cable into the same location as the previous screen. (Location noted in picture by arrow). Make sure the cable is placed facing downward on the connection.
      • Lower the motherboard into place. Make sure to keep the back facing downward. Hint: This will be the side where all cables are connected.
      • Gently lay the screen on the core of the device.
      Ask FixBot
    13. Tungsten T3 Motherboard Replacement: step 13, image 1 of 2 Tungsten T3 Motherboard Replacement: step 13, image 2 of 2
      • Lay the face plate on device. It must be snapped into place.
      Ask FixBot
    14. Tungsten T3 Motherboard Replacement: step 14, image 1 of 1
      • When attaching the tray to the main device, the cable must be in the position as seen in the left figure.
      • On each side, the prongs must be adjusted so that they fit into their respective slots.
      Ask FixBot
    15. Tungsten T3 Motherboard Replacement: step 15, image 1 of 1
      • To reconnect the sliding tray and buttons, lay the device on its face.
      • The orange button cable must be raised above sliding tray and connected to its respective port (as seen in picture).
      Ask FixBot
    16. Tungsten T3 Motherboard Replacement: step 16, image 1 of 1
      • To reconnect the sliding track, align the hooks and tracks (noted in picture).
      • Push the hooks into the tracks and slide the tray upward. This should lock the hooks in place.
      • To ensure that it has been connected properly, slide up and down.
      Ask FixBot
    17. Tungsten T3 Motherboard Replacement: step 17, image 1 of 1
      • Install the screws on both sides of device as seen in the picture.
      • You can refer to step 2. We will just be inserting the original screws into place.
      Ask FixBot
    18. Tungsten T3 Motherboard Replacement: step 18, image 1 of 1
      • Here is your repaired Tungsten T3 Palm Pilot. Enjoy!
      Ask FixBot
Whitney
318 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 35
All Time: 1,627
