Up to 20% off select tools
Trunk LED Tailgate Strip Light Installation
Views: 45K
View statistics:
Past 24 Hours:
8
Past 7 Days:
44
Past 30 Days:
215
All Time:
45,386
Comments: 27
6 comments on steps, 21 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This LED strip gives your truck a more kickass appearance to complete the look. It's not every day that you see trucks with some pretty neat LED strip lights so be the first one on the road to have LED tailgate strip lamps! These are LED tail gate strip lights with 4 functions: on/off brake mode, left turn signal, right turn signal, and reverse mode. These LED strip lights are universal fit so you don't have to worry about compatibility issues.
    1. Trunk LED Tailgate Strip Light Installation, Cleaning: step 1, image 1 of 2 Trunk LED Tailgate Strip Light Installation, Cleaning: step 1, image 2 of 2
      • Thoroughly clean the surface where you'll be applying the trunk LED tail gate lamp.
      • Use soap and water to scrub the area clean since that place is normally dirty.
      Ask FixBot
    2. Trunk LED Tailgate Strip Light Installation, Mounting time: step 2, image 1 of 2 Trunk LED Tailgate Strip Light Installation, Mounting time: step 2, image 2 of 2
      • Carefully measure beforehand where you're going to attach the LED strip so it looks even.
      • The LED tailgate strip is designed to be a little bit shorter than the trunk tailgate.
      • Straighten the LED strip and peel adhesive.
      • OPTIONAL: The package includes 4 mounting brackets with screws. You can use these to further secure the LED tailgate lights.
      Ask FixBot
    3. Trunk LED Tailgate Strip Light Installation, Wire tapping: step 3, image 1 of 3 Trunk LED Tailgate Strip Light Installation, Wire tapping: step 3, image 2 of 3 Trunk LED Tailgate Strip Light Installation, Wire tapping: step 3, image 3 of 3
      • Tap reverse light wire.
      • You will need to remove either side of the tail light to locate the reverse light.
      • Use a T-tap to tap the reverse light wire from the tailgate LED strip to positive.
      Ask FixBot
    4. Trunk LED Tailgate Strip Light Installation, Find the connector: step 4, image 1 of 2 Trunk LED Tailgate Strip Light Installation, Find the connector: step 4, image 2 of 2
      • This is the trailer light connector. You can see: ground, brake, left signal, right signal - plug that into stock trailer light connector.
      • You will find the trailer light connector near the tow hitch.
      Ask FixBot
    5. Trunk LED Tailgate Strip Light Installation, Test and enjoy: step 5, image 1 of 3 Trunk LED Tailgate Strip Light Installation, Test and enjoy: step 5, image 2 of 3 Trunk LED Tailgate Strip Light Installation, Test and enjoy: step 5, image 3 of 3
      • Hide the wires or zip-tie them.
      • Check the trunk LED tailgate lamp to make sure everything works.
      Ask FixBot
You're now on your way to being the coolest truck on the road with your new trunk LED tailgate strip lights!
5 other people completed this guide.
Author
with
Eric Wu
3,600 Reputation
23 Guides authored
21 Guide Comments
Should my light bar come on with my headlights they worked without the headlights but when I turn headlights on they don't work what's wrong
Anthony Carter - Reply Share
did you get a answer to your problem because I'm having the same problem
marshallsdawgs07 - Reply Share
Anyone have the answer to this problem yet?
Trevor G - Reply Share
I'm having the same problem!
Richie - Reply Share
I bought a led third brake below the tailgate and i have five wires on the led light.what is the wiring diagram for it
Spencer Sherrod - Reply Share
Past 24 Hours: 8
Past 7 Days: 44
Past 30 Days: 215
All Time: 45,386
