Trumpet Stem Felt Replacement
Views: 1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
37
Past 30 Days:
115
All Time:
1,007
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Over time, regular use of the trumpet can lead to the degradation of the felt material. The stem felt can wear down from friction against the valve, deteriorate due to moisture from breath or saliva, or accumulate dirt or debris. Here is the process of replacing the stem felt in a trumpet's valve.
    1. Trumpet Stem Felt Replacement, Stem Felt: step 1, image 1 of 1
      • Loosen and remove the top valve cap from the trumpet body.
      Ask FixBot
    2. Trumpet Stem Felt Replacement: step 2, image 1 of 1
      • Pull the valve out of the trumpet body.
      Ask FixBot
    3. Trumpet Stem Felt Replacement: step 3, image 1 of 2 Trumpet Stem Felt Replacement: step 3, image 2 of 2
      • Loosen and remove the finger button from the end of the stem.
      Ask FixBot
    4. Trumpet Stem Felt Replacement: step 4, image 1 of 1
      • Remove the top valve cap from the stem.
      Ask FixBot
    5. Trumpet Stem Felt Replacement: step 5, image 1 of 1
      • Carefully pull the used stem felt off of the base of the stem and remove it from the stem.
      Ask FixBot
    6. Trumpet Stem Felt Replacement: step 6, image 1 of 1
      • Fit the new stem felt onto the stem and push it down onto the base.
      Ask FixBot
Nathan
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 115
All Time: 1,007
