Truma Combi 4 Recirculating Air Fan Wheel Cleaning
Views: 2.3K
View statistics:
Past 24 Hours:
10
Past 7 Days:
50
Past 30 Days:
199
All Time:
2,270
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 hours
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, I'll show you how to clean the recirculating air fan wheel of the Truma Combi 4.
    1. Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Preparing the Lid: step 1, image 1 of 1
      • slide the cover slightly upwards
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Fan Wheel Cleaning, hebe den Deckel nach vorne aus der Schiene: step 2, image 1 of 3 Truma Combi 4 Recirculating Air Fan Wheel Cleaning, hebe den Deckel nach vorne aus der Schiene: step 2, image 2 of 3 Truma Combi 4 Recirculating Air Fan Wheel Cleaning, hebe den Deckel nach vorne aus der Schiene: step 2, image 3 of 3
      • lift the cover forwards out of the rail
      • pay attention to the detents / tabs on the rail
      Ask FixBot
    1. Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Removing the Housing Screws: step 3, image 1 of 1
      • remove the four screws with the Torx 20 screwdriver
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Removing the Cover: step 4, image 1 of 3 Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Removing the Cover: step 4, image 2 of 3 Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Removing the Cover: step 4, image 3 of 3
      • lift the cover forwards over the connections
      Ask FixBot
    1. Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Removing the Screws: step 5, image 1 of 1
      • remove the four screws of the cover with the Torx 20 screwdriver
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Removing the cover: step 6, image 1 of 2 Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Removing the cover: step 6, image 2 of 2
      • lift the cover away from the fan wheel
      Ask FixBot
    1. Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Positioning the Fan Whee: step 7, image 1 of 2 Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Positioning the Fan Whee: step 7, image 2 of 2
      • Position the fan wheel by turning it so that, ...
      • ... that the hole in the fan wheel is facing upwards
      Ask FixBot
    2. Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Loosening the Allen Screw: step 8, image 1 of 2 Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Loosening the Allen Screw: step 8, image 2 of 2
      • The screw locks the wheel onto the motor shaft and only needs to be loosened, not completely removed!
      • Now, loosen the Allen screw with the 2mm Allen key.
      • Loosen the screw using the long end as a lever.
      • loosen (do not remove!) the screw from above until the wheel can be pulled off the motor shaft without any problems
      Ask FixBot
    3. Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Removing the Fan Wheel: step 9, image 1 of 2 Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Removing the Fan Wheel: step 9, image 2 of 2
      • Pull the wheel straight off the motor shaft.
      Ask FixBot
    1. Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Cleaning the Blades: step 10, image 1 of 2 Truma Combi 4 Recirculating Air Fan Wheel Cleaning, Cleaning the Blades: step 10, image 2 of 2
      • Be careful when handling the wheel! If there is even a slight imbalance, bend, notch, or other damage, the wheel must be replaced. Otherwise, vibrations, whistling, and other disruptive noises will be the result!
      • If it is heavily soiled, clean the fins individually and carefully with cotton swabs.
      • Do not use any other materials, especially no metal objects! The fins are very sensitive.
      Ask FixBot
To reassemble your device, follow the steps in reverse order.
Special thanks to these translators:
de en
100%
hainzy is helping us fix the world! Want to contribute?
Start translating ›
hainzy
11,183 Reputation
48 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 50
Past 30 Days: 199
All Time: 2,270
