Tristar Handmixer Gears Replacement
    1. Tristar Handmixer Gears Replacement, Gears: step 1, image 1 of 3 Tristar Handmixer Gears Replacement, Gears: step 1, image 2 of 3 Tristar Handmixer Gears Replacement, Gears: step 1, image 3 of 3
      • Remove all the screws with the spanner and Phillips screwdrivers.
      Ask FixBot
    2. Tristar Handmixer Gears Replacement: step 2, image 1 of 3 Tristar Handmixer Gears Replacement: step 2, image 2 of 3 Tristar Handmixer Gears Replacement: step 2, image 3 of 3
      • Take off the mixer heads.
      • Push the eject button to do so.
      • Put the mixer in mode 5.
      • Gently open the mixer.
      • The spring might jump loose!!
      Ask FixBot
    3. Tristar Handmixer Gears Replacement: step 3, image 1 of 3 Tristar Handmixer Gears Replacement: step 3, image 2 of 3 Tristar Handmixer Gears Replacement: step 3, image 3 of 3
      • Remove the eject button by carefully lifting it out.
      • Remove the cable holder using the Phillips screw driver.
      • Remove the screw holding the mode button.
      • Carefully lift out the electrical unit.
      Ask FixBot
    4. Tristar Handmixer Gears Replacement: step 4, image 1 of 2 Tristar Handmixer Gears Replacement: step 4, image 2 of 2
      • Remove the locking rings from the back end of the gears.
      • Use 2 screwdrivers to apply force on both sides of the locking rings.
      • Lift the gears from encapsulant.
      Ask FixBot
    5. Tristar Handmixer Gears Replacement: step 5, image 1 of 1
      • Replace gears.
      • Reassemble the mixer.
      • Happy mixing!
      Ask FixBot
2 other people completed this guide.
3 Guide Comments
where can I get replacement gears from?
lanz - Reply Share
Thats what I want to know too. I have a Hamilton Beach hand mixer. The gears look the same as the one shown in this article
Shaik Shahnaz - Reply Share
On it now. Let's hope we don't need to buy Cheap-China-plastic. Ideal of course would be to find metal gears, that would last whole life (if not motor breaks).
I also need to find a manufacturer of cog drive train wheels, that could do custom made, tailored, because if you refurbish a vintage handmixer you need parts that are not manufactured or in circulation anymore.
Henry - Reply Share
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 68
All Time: 2,764
