Trio Stealth-G4X Speaker Replacement
    1. Trio Stealth-G4X Speaker Replacement, Speaker: step 1, image 1 of 1
      • Starting near the middle edge of the Trio Stealth-G4X tablet, gently work the small pry tool in between the seams of one side of the tablet.
      Ask FixBot
    2. Trio Stealth-G4X Speaker Replacement: step 2, image 1 of 1
      • Work your way around all four corners of the tablet, unlocking all of the retaining tabs that hold the tablet together.
      • Be sure not to over penetrate while separating the two halves as you may damage the tablet's internal hardware.
      Ask FixBot
    3. Trio Stealth-G4X Speaker Replacement: step 3, image 1 of 1
      • You should now be able to separate the two halves of the tablet. Also place the back cover aside since you will no longer be needing it until reassembly.
      Ask FixBot
    4. Trio Stealth-G4X Speaker Replacement: step 4, image 1 of 1
      • With the motherboard facing upwards, locate the speakers and the Braided (Red and Black) wires connecting them. Once located remove the two pieces of black adhesive tape retaining the wires using a small pry tool or your hands.
      Ask FixBot
    5. Trio Stealth-G4X Speaker Replacement: step 5, image 1 of 1
      • Once removed you will notice the solder locations that connect the Braided (Red and Black) wires to the motherboard.
      Ask FixBot
    6. Trio Stealth-G4X Speaker Replacement: step 6, image 1 of 1
      • Follow the speaker wires down to the speakers at the bottom of the tablet.
      Ask FixBot
    7. Trio Stealth-G4X Speaker Replacement: step 7, image 1 of 1
      • Use the pry tool to gently loosen the speakers out of place. Once loose separate the two sets of speakers so that you can identify which one must be replaced and which solder points you must desolder in the next steps.
      Ask FixBot
    8. Trio Stealth-G4X Speaker Replacement: step 8, image 1 of 1
      • Look closely at the soldering points. Take note of how the positive(Red) and negative(Black) connections are placed on the motherboard. With your soldering iron carefully heat the solder point until it begins to melt. Once molten, gently pull the wire off of the connection point. De-solder both positive and negative wires for each problem speaker.
      Ask FixBot
    9. Trio Stealth-G4X Speaker Replacement: step 9, image 1 of 1
      • Re-soldering is the same process as de-soldering, except you will also add solder. Be sure to be precise and clean when soldering. Look up soldering tutorials for help on youtube if you do not feel comfortable. Once all wires are re-soldered reassemble the tablet following the steps in reverse order.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 74
All Time: 556
