Up to 20% off select tools
Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
87
All Time:
986
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
Introduction
Go to step 1 ↓
If the front-facing or rear-facing camera on your Trio Stealth-10 is no longer functioning, replacement isn't difficult and this guide will give you the step by step procedure to do so.
    1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Back Panel: step 1, image 1 of 1
      • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
      Ask FixBot
    1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Front-Facing/ Rear-Facing Camera: step 2, image 1 of 1
      • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
      Ask FixBot
    2. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: step 3, image 1 of 1
      • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
      Ask FixBot
    3. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: step 4, image 1 of 1
      • Remove the first layer of tape above camera cable connection slowly.
      Ask FixBot
    4. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: step 5, image 1 of 1
      • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
      Ask FixBot
2 other people completed this guide.
Author
with
Daniel Coleman
643 Reputation
5 Guides authored
UMass Dartmouth, Team 1-4, Miles Fall 2015 Member of UMass Dartmouth, Team 1-4, Miles Fall 2015
UMASSD-MILES-F15S1G4
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 87
All Time: 986
