Trio Stealth G2 Hype Battery Replacement
    1. Trio Stealth G2 Hype Battery Replacement, Back Panel: step 1, image 1 of 2 Trio Stealth G2 Hype Battery Replacement, Back Panel: step 1, image 2 of 2
      • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
      Ask FixBot
    2. Trio Stealth G2 Hype Battery Replacement: step 2, image 1 of 1
      • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
      • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
      Ask FixBot
    3. Trio Stealth G2 Hype Battery Replacement: step 3, image 1 of 3 Trio Stealth G2 Hype Battery Replacement: step 3, image 2 of 3 Trio Stealth G2 Hype Battery Replacement: step 3, image 3 of 3
      • Remove the speakers by using your hand to entirely disconnect the back cover.
      Ask FixBot
    1. Trio Stealth G2 Hype Battery Replacement, Speakers: step 4, image 1 of 2 Trio Stealth G2 Hype Battery Replacement, Speakers: step 4, image 2 of 2
      • Carefully peel the tape holding down the wires connected to the speaker.
      Ask FixBot
    2. Trio Stealth G2 Hype Battery Replacement: step 5, image 1 of 1
      • In order to replace the speakers after they are removed, you must solder the wires back onto the motherboard.
      • The red wire must be soldered onto the "+" terminal while the black wire must be terminal must be soldered onto the "-" terminal.
      • Pull the speaker and wires from the motherboard.
      Ask FixBot
    1. Trio Stealth G2 Hype Battery Replacement, Battery: step 6, image 1 of 2 Trio Stealth G2 Hype Battery Replacement, Battery: step 6, image 2 of 2
      • While holding the mother board down, slowly remove the battery from tape on the back of the screen.
      • Make sure to keep all wires attached for now.
      Ask FixBot
    2. Trio Stealth G2 Hype Battery Replacement: step 7, image 1 of 1
      • In order to replace the battery once the wires are removed, you will need to solder the wires of the new battery onto the motherboard.
      • The red wire must be soldered to the "+" terminal while the black is soldered to the "-" terminal.
      • Pull the wires off the motherboard.
      Ask FixBot
2 other people completed this guide.
Thomas Lichtenberger
459 Reputation
3 Guides authored
USF Tampa, Team 4-4, Brown Winter 2015 Member of USF Tampa, Team 4-4, Brown Winter 2015
USFT-BROWN-W15S4G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 35
All Time: 2,588
