Trio Stealth G2 Hype Back Panel Replacement
    1. Trio Stealth G2 Hype Back Panel Replacement, Back Panel: step 1, image 1 of 2 Trio Stealth G2 Hype Back Panel Replacement, Back Panel: step 1, image 2 of 2
      • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
      Ask FixBot
    2. Trio Stealth G2 Hype Back Panel Replacement: step 2, image 1 of 1
      • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
      • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
      Ask FixBot
    3. Trio Stealth G2 Hype Back Panel Replacement: step 3, image 1 of 3 Trio Stealth G2 Hype Back Panel Replacement: step 3, image 2 of 3 Trio Stealth G2 Hype Back Panel Replacement: step 3, image 3 of 3
      • Remove the speakers by using your hand to entirely disconnect the back cover.
      Ask FixBot
Thomas Lichtenberger
459 Reputation
3 Guides authored
USF Tampa, Team 4-4, Brown Winter 2015 Member of USF Tampa, Team 4-4, Brown Winter 2015
USFT-BROWN-W15S4G4
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 64
All Time: 993
