Up to 20% off select tools
Trio STEALTH-9 Battery Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
87
All Time:
2,145
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Here, you will be working with live wires on a power source! Be very careful when you desolder them, and make sure you don't let the leads touch!
    1. Trio STEALTH-9 Battery Replacement, Back Cover: step 1, image 1 of 1
      • Remove the two Phillips #00 screws on the side of the tablet.
      Ask FixBot
    2. Trio STEALTH-9 Battery Replacement: step 2, image 1 of 1
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      Ask FixBot
    3. Trio STEALTH-9 Battery Replacement: step 3, image 1 of 1
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      Ask FixBot
    4. Trio STEALTH-9 Battery Replacement: step 4, image 1 of 1
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      Ask FixBot
    1. Trio STEALTH-9 Battery Replacement, Battery: step 5, image 1 of 1
      • With the cover removed, slowly pull the electrical tape away as shown.
      Ask FixBot
    2. Trio STEALTH-9 Battery Replacement: step 6, image 1 of 1
      • Slowly pull the Battery away from the tablet frame.
      Ask FixBot
    3. Trio STEALTH-9 Battery Replacement: step 7, image 1 of 1
      • Prepare your Soldering Iron and Removal Tools.
      • Contact the iron with each of the battery leads, and pull the lead away from the board.
      • Remove any excess solder as needed.
      Ask FixBot
    4. Trio STEALTH-9 Battery Replacement: step 8, image 1 of 1
      • To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
      • Apply heat and solder to each lead individually.
      • Remove any excess solder if flooding occurs.
      Ask FixBot
To replace the battery, you must re-solder the leads on the battery into the motherboard. You MUST make sure that the leads were in the correct order as when you started.
Author
with
[deleted]
415 Reputation
3 Guides authored
1 Guide Comment
Is it possible that the wiring to the battery just became loose and I could use these same directions and reconnect or solder (or do both?) The existing battery ?
Jessie ussery - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 87
All Time: 2,145
