Trio AXS 3G Speaker Replacement
    1. Trio AXS 3G Speaker Replacement, Back Case: step 1, image 1 of 1
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      Ask FixBot
    2. Trio AXS 3G Speaker Replacement: step 2, image 1 of 2 Trio AXS 3G Speaker Replacement: step 2, image 2 of 2
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      Ask FixBot
    3. Trio AXS 3G Speaker Replacement: step 3, image 1 of 1
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      Ask FixBot
    1. Trio AXS 3G Speaker Replacement, Speaker: step 4, image 1 of 1
      • Unscrew the two 4 mm #000 screws.
      Ask FixBot
    2. Trio AXS 3G Speaker Replacement: step 5, image 1 of 1
      • Use a soldering iron to desolder the speaker connection.
      • Be careful not to melt the wires.
      Ask FixBot
    3. Trio AXS 3G Speaker Replacement: step 6, image 1 of 1
      • Remove the speaker.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 27
All Time: 509
