Up to 20% off select tools
Trio AXS 3G Screen Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
86
All Time:
1,610
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace your tablet's screen.
    1. Trio AXS 3G Screen Replacement, Back Case: step 1, image 1 of 1
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      Ask FixBot
    2. Trio AXS 3G Screen Replacement: step 2, image 1 of 2 Trio AXS 3G Screen Replacement: step 2, image 2 of 2
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      Ask FixBot
    3. Trio AXS 3G Screen Replacement: step 3, image 1 of 1
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      Ask FixBot
    1. Trio AXS 3G Screen Replacement, Screen: step 4, image 1 of 1
      • The motherboard and battery will have to be removed to expose the metal panel underneath.
      Ask FixBot
    2. Trio AXS 3G Screen Replacement: step 5, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Use the plastic card to pry the battery away from the device.
      • The battery is attached to the tablet by glue.
      Ask FixBot
    3. Trio AXS 3G Screen Replacement: step 6, image 1 of 1
      • Peel off the battery from the device and set aside.
      • The battery is connected to the motherboard by two wires. Be careful not to sever the connection.
      Ask FixBot
    4. Trio AXS 3G Screen Replacement: step 7, image 1 of 1
      • Using a #000 screwdriver, unscrew the five 4mm and 3 mm screws connecting the top portion of the motherboard to the device.
      Ask FixBot
    5. Trio AXS 3G Screen Replacement: step 8, image 1 of 1
      • Disconnect the silver tape that attaches the motherboard to the metal panel.
      Ask FixBot
    6. Trio AXS 3G Screen Replacement: step 9, image 1 of 1
      • Disconnect the ribbon from the bottom portion of the motherboard.
      Ask FixBot
    7. Trio AXS 3G Screen Replacement: step 10, image 1 of 1
      • Remove the motherboard and set aside.
      Ask FixBot
    8. Trio AXS 3G Screen Replacement: step 11, image 1 of 1
      • The smaller portion of the motherboard is located at the bottom with the speaker.
      • Using a #000 screwdriver, unscrew the three 3 mm screws that fasten the smaller segment of the motherboard to the tablet.
      Ask FixBot
    9. Trio AXS 3G Screen Replacement: step 12, image 1 of 2 Trio AXS 3G Screen Replacement: step 12, image 2 of 2
      • Located towards the bottom, carefully remove the yellow film.
      Ask FixBot
    10. Trio AXS 3G Screen Replacement: step 13, image 1 of 1
      • Gently disconnect the small ribbon found underneath the film.
      Ask FixBot
    11. Trio AXS 3G Screen Replacement: step 14, image 1 of 1
      • There is another connection found underneath this portion of the motherboard.
      • Lifting up the motherboard, disconnect the second ribbon found underneath.
      Ask FixBot
    12. Trio AXS 3G Screen Replacement: step 15, image 1 of 1
      • Unscrew the two 4 mm #000 screws.
      Ask FixBot
    13. Trio AXS 3G Screen Replacement: step 16, image 1 of 1
      • Remove the speaker and bottom portion of the motherboard.
      Ask FixBot
    14. Trio AXS 3G Screen Replacement: step 17, image 1 of 1
      • At this stage, almost all inside components should be removed (as shown).
      • Using a screwdriver size #000, remove the four 4 mm screws found at each corner of the metal panel if you haven't gotten them already.
      Ask FixBot
    15. Trio AXS 3G Screen Replacement: step 18, image 1 of 3 Trio AXS 3G Screen Replacement: step 18, image 2 of 3 Trio AXS 3G Screen Replacement: step 18, image 3 of 3
      • Use the plastic card to separate the metal panel from the screen component.
      Ask FixBot
    16. Trio AXS 3G Screen Replacement: step 19, image 1 of 1
      • Separate memory card from screen.
      Ask FixBot
    17. Trio AXS 3G Screen Replacement: step 20, image 1 of 2 Trio AXS 3G Screen Replacement: step 20, image 2 of 2
      • Use the plastic card to separate screen component from front panel.
      Ask FixBot
    18. Trio AXS 3G Screen Replacement: step 21, image 1 of 1
      • Use the plastic card to separate the glass from the front panel.
      • Once the glass is removed, the new glass can be fitted to the front panel.
      Ask FixBot
Author
with
Michaela Causey
328 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 86
All Time: 1,610
