Up to 20% off select tools
Trio AXS 3G Back Case Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
79
All Time:
969
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The back panel contains the more important components of the tablet such as the speaker, camera, motherboard, and more.
    1. Trio AXS 3G Back Case Replacement, Back Case: step 1, image 1 of 1
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      Ask FixBot
    2. Trio AXS 3G Back Case Replacement: step 2, image 1 of 2 Trio AXS 3G Back Case Replacement: step 2, image 2 of 2
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      Ask FixBot
    3. Trio AXS 3G Back Case Replacement: step 3, image 1 of 1
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      Ask FixBot
Author
with
Javoy Ross
316 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 79
All Time: 969
