Tribit XSound Go TS-BTS20 Battery Replacement
    1. Tribit XSound Go TS-BTS20 Battery Replacement, Battery: step 1, image 1 of 2 Tribit XSound Go TS-BTS20 Battery Replacement, Battery: step 1, image 2 of 2
      • Insert a spudger in the seam between the front speaker grill and chassis.
      • Pry around the perimeter until the front grill releases.
      • Remove the front grill.
      Ask FixBot
    2. Tribit XSound Go TS-BTS20 Battery Replacement: step 2, image 1 of 1
      • Remove the 14 Phillips screws around the perimeter of the speaker.
      • Lift off the speaker housing.
      Ask FixBot
    3. Tribit XSound Go TS-BTS20 Battery Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Disconnect the white speaker connections by gently pulling up with tweezers.
      Ask FixBot
    4. Tribit XSound Go TS-BTS20 Battery Replacement: step 4, image 1 of 1
      • Find the battery cover.
      • Use a screwdriver to unscrew the sides of the covering.
      Ask FixBot
    5. Tribit XSound Go TS-BTS20 Battery Replacement: step 5, image 1 of 1
      • Pull the covering up with a pair of tweezers.
      Ask FixBot
    6. Tribit XSound Go TS-BTS20 Battery Replacement: step 6, image 1 of 1
      • Disconnect the batteries by pulling the battery connectors directly out of their motherboard ports.
      Ask FixBot
    7. Tribit XSound Go TS-BTS20 Battery Replacement: step 7, image 1 of 1
      • Gently pull the batteries out of the speaker.
      Ask FixBot
3 other people completed this guide.
6 Guide Comments
I couldn't find online the exact battery replacement, any suggestions?
fred - Reply Share
Same here. What is the replacement battery number?
jay.8garrison@gmail.com - Reply Share
I am having difficulty finding a replacement battery with the same configuration as what is shown and in my device. I am going to try reaching out to the company’s customer service and see what they have to say.
Chester LaBruyere - Reply Share
After disassembling and seeing unusual batteries, I DID contact the company. Here’s the response: “Kindly note that the built-in battery of our speaker is composed of several lithium batteries in series and parallel, we do not recommend disassembly it. We also do not sell separate batteries.”
So my question is - why the detailed and intricate instructions for a dead end that wasn’t even suggested where you mention in the Introduction, “This guide will help you replace the batteries …”
Tinkerer beware.
Ravani Leffler - Reply Share
Need to buy battery for tribit xsound go
John Hemrom - Reply Share
Past 24 Hours: 14
Past 7 Days: 91
Past 30 Days: 327
All Time: 7,222
