Tribit Stormbox IC-BTS30 Volume Buttons Replacement
    1. Tribit Stormbox IC-BTS30 Volume Buttons Replacement, Front Panel: step 1, image 1 of 3 Tribit Stormbox IC-BTS30 Volume Buttons Replacement, Front Panel: step 1, image 2 of 3 Tribit Stormbox IC-BTS30 Volume Buttons Replacement, Front Panel: step 1, image 3 of 3
      • Place the speaker on your work surface.
      • Use a plastic opening tool to lift the edge of the rubber base and peel it away from the housing.
      • Set the rubber base aside.
      Ask FixBot
    2. Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 2, image 1 of 2 Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 2, image 2 of 2
      • Remove the 5.4 mm screw securing the small carry strap using a 4 mm flathead screwdriver.
      • Gently slide the strap and its plastic bracket out of place.
      • Set the strap and screw aside.
      Ask FixBot
    3. Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 3, image 1 of 3 Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 3, image 2 of 3 Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 3, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the 11.4 mm screws along the panel.
      • Gently lift the rubber control panel away from the housing.
      Ask FixBot
    1. Tribit Stormbox IC-BTS30 Volume Buttons Replacement, Volume Buttons: step 4, image 1 of 3 Tribit Stormbox IC-BTS30 Volume Buttons Replacement, Volume Buttons: step 4, image 2 of 3 Tribit Stormbox IC-BTS30 Volume Buttons Replacement, Volume Buttons: step 4, image 3 of 3
      • On the opposite side of the speaker's charging port, you can locate the volume buttons, which can be easily seen as a white rubber surface.
      • Using the plastic pry tool, we will remove the rubber piece to expose the circuit board for the volume buttons.
      Ask FixBot
    2. Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 5, image 1 of 3 Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 5, image 2 of 3 Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 5, image 3 of 3
      • On the upper half of the volume circuit board, there's is a thin wire that is connected to the circuit. To remove the wire, locate the two black squares that is above and below the wire.
      • Using the plastic prying tool, gently push the squares to the right to unlock the wire.
      • When the wire is unlocked, slowly disconnect the wire from the circuit board.
      Ask FixBot
    3. Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 6, image 1 of 3 Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 6, image 2 of 3 Tribit Stormbox IC-BTS30 Volume Buttons Replacement: step 6, image 3 of 3
      • To remove the circuit board, we will slowly pry out it out using the plastic pry tool since the circuit is taped to the device.
      • Gently pull the circuit board out once it is pried out since it is fragile.
      • When finished, you may set the circuit board aside.
      Ask FixBot
Finish Line
Kent Mopal
343 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 21
All Time: 134
