Triace A310 Tire Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
75
All Time:
980
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If you need to remove your tire for any reason, this guide will help you safely remove it.
    1. Triace A310 Tire Disassembly, Tire: step 1, image 1 of 1
      • Begin loosening the tire by turning the quick release handle.
      Ask FixBot
    2. Triace A310 Tire Disassembly: step 2, image 1 of 2 Triace A310 Tire Disassembly: step 2, image 2 of 2
      • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
      • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
      Ask FixBot
    3. Triace A310 Tire Disassembly: step 3, image 1 of 2 Triace A310 Tire Disassembly: step 3, image 2 of 2
      • There should be enough slack, in the chain, at this point to remove the tire from the bike.
      • Note: You may need to wiggle the tire and chain around in order to create enough slack.
      • Remove the tire from the bike.
      Ask FixBot
To reassemble your device, please follow these steps in reverse order.
Daniel
222 Reputation
2 Guides authored
Cal Poly, Team 1-37, Maness Winter 2014 Member of Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 75
All Time: 980
