Triace A310 Disk Brake Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
95
All Time:
1,224
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
In order to have a safer biking experience, make sure your disk brake is properly replaced.
Tools
    1. Triace A310 Disk Brake Replacement, Tire: step 1, image 1 of 1
      • Begin loosening the tire by turning the quick release handle.
      Ask FixBot
    2. Triace A310 Disk Brake Replacement: step 2, image 1 of 2 Triace A310 Disk Brake Replacement: step 2, image 2 of 2
      • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
      • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
      Ask FixBot
    3. Triace A310 Disk Brake Replacement: step 3, image 1 of 2 Triace A310 Disk Brake Replacement: step 3, image 2 of 2
      • There should be enough slack, in the chain, at this point to remove the tire from the bike.
      • Note: You may need to wiggle the tire and chain around in order to create enough slack.
      • Remove the tire from the bike.
      Ask FixBot
    1. Triace A310 Disk Brake Replacement, Disk Brake: step 4, image 1 of 1
      • Place the tire flat on the ground making sure the disk is facing you.
      Ask FixBot
    2. Triace A310 Disk Brake Replacement: step 5, image 1 of 3 Triace A310 Disk Brake Replacement: step 5, image 2 of 3 Triace A310 Disk Brake Replacement: step 5, image 3 of 3
      • Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
      • Make sure to keep track of all of the removed pieces.
      Ask FixBot
    3. Triace A310 Disk Brake Replacement: step 6, image 1 of 2 Triace A310 Disk Brake Replacement: step 6, image 2 of 2
      • After all of the screws have been removed, take the disk and pull it away from the tire.
      Ask FixBot
Daniel
222 Reputation
2 Guides authored
Cal Poly, Team 1-37, Maness Winter 2014 Member of Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 95
All Time: 1,224
