Trek 820 Tail Light Mounting Bracket Replacement
    1. Trek 820 Tail Light Mounting Bracket Replacement, Tail Light Mounting Bracket: step 1, image 1 of 1
      • Obtain one tail light mounting bracket and one screw as shown in the picture.
      • The screw should be removed from the mounting bracket.
      Ask FixBot
    2. Trek 820 Tail Light Mounting Bracket Replacement: step 2, image 1 of 1
      • Clean the bicycle seat post and mounting bracket.
      • Wrap the mounting bracket strap around the seat post.
      • Verify the larger piece rests towards the tail end aligned with the tires.
      • Verify the bracket's screw hole is on the right side of the bicycle.
      Ask FixBot
    3. Trek 820 Tail Light Mounting Bracket Replacement: step 3, image 1 of 2 Trek 820 Tail Light Mounting Bracket Replacement: step 3, image 2 of 2
      • Locate the slot on the bracket where the strap will be inserted.
      • Insert the strap into the slot.
      • Tighten the strap just enough to keep the bracket in place.
      Ask FixBot
    4. Trek 820 Tail Light Mounting Bracket Replacement: step 4, image 1 of 2 Trek 820 Tail Light Mounting Bracket Replacement: step 4, image 2 of 2
      • Insert the screw into the bracket screw hole.
      • Tighten the screw with fingers until the mounting bracket rests freely on seat post.
      Ask FixBot
Kaveh Karimiyanha
822 Reputation
7 Guides authored
Cal Poly, Team 1-1, Propen Fall 2012 Member of Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 35
All Time: 1,595
