Up to 20% off select tools
Trek 820 Spokes Replacement
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
107
All Time:
3,038
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
This guide covers how to replace a snapped or broken spoke on the front wheel of a Trek 820 Mountain Bike.
All the spokes in a wheel work together to provide structural integrity and ensure alignment. Spokes may malfunction if too large a concentrated force is exerted on the wheel. One way to check for a bent spoke is to spin the wheel, and see if it wobbles in between the brake pads. If you don't replace a bent or broken spoke, adjacent spokes may become damaged as a result of compensating for the broken one. If the wheel falls out of alignment due to a broken spoke, the brakes may also rub on the rim. This adds unnecessary friction which prematurely wears out the brake pads and slows you down. If your rim becomes too wobbly due to broken or loose spokes, there will be more steps required past replacing the spokes. Reference this guide on how to true a wheel.
Caution: If the spoke has snapped, the end of it may become sharp.
    1. Trek 820 Spokes Replacement, Front Wheel: step 1, image 1 of 2 Trek 820 Spokes Replacement, Front Wheel: step 1, image 2 of 2
      • Facing your bike, straddle your front wheel between your knees.
      • Locate the front brake at the top of the fork. It will more than likely look like the picture on your left.
      • Since the tire is normally wider than the space between the brake pads, you must first release the tension in the brake wire. To do this, run your right hand under both brake calipers and push them inwards towards one another.
      Ask FixBot
    2. Trek 820 Spokes Replacement: step 2, image 1 of 2 Trek 820 Spokes Replacement: step 2, image 2 of 2
      • With the brake wire sufficiently loosened, unhook the metal tube that contains the brake wire (called the noodle) from the brake wire holder using your left hand.
      • The brake will now be open wide enough to permit removal of the wheel.
      Ask FixBot
    3. Trek 820 Spokes Replacement: step 3, image 1 of 2 Trek 820 Spokes Replacement: step 3, image 2 of 2
      • Find the quick release lever on the outside of the bike's fork on the right hand side. Flip the lever down and turn the lever counter clockwise, loosening the lever until it comes off.
      Ask FixBot
    4. Trek 820 Spokes Replacement: step 4, image 1 of 1
      • After the quick release lever is removed, the wheel can be separated from the front fork.
      Ask FixBot
      • In reassembling the wheel to the bike, perform the steps in reverse order.
      • With the axle all the way into the fork slots, tighten the quick release lever into the fork end securely. It should take a modest amount of force applied to tighten the axle to the fork.
      • Squeeze the brake calipers together and return the cable noodle back into the holder.
      • Make sure you go back, and check to make sure its snug so that the wheel has no way of coming back off.
      Ask FixBot
    1. Trek 820 Spokes Replacement, Tire: step 6, image 1 of 1
      • Locate the valve stem and remove the valve stem cap if one is present.
      Ask FixBot
    2. Trek 820 Spokes Replacement: step 7, image 1 of 1
      • Begin releasing tire air pressure by pressing down on the small rod in the center of the valve stem. A hissing sound will indicated that air is leaving the tire.
      • Continue to release air until the tire becomes soft and flexible. The hissing sound should become quiet or stop altogether.
      Ask FixBot
    3. Trek 820 Spokes Replacement: step 8, image 1 of 2 Trek 820 Spokes Replacement: step 8, image 2 of 2
      • Insert the flathead screwdriver, or another sturdy, long object, between the edge of the tire and the wheel rim.
      • Be careful not to damage the inner tube when inserting and moving the screwdriver or other tool. The inner tube is fragile and may be pinched between the wheel rim and tool.
      • Work the edge of the tire out of the wheel rim using a screwdriver, pulling the edge of the tire away from the center of the wheel and out of the rim.
      Ask FixBot
    4. Trek 820 Spokes Replacement: step 9, image 1 of 3 Trek 820 Spokes Replacement: step 9, image 2 of 3 Trek 820 Spokes Replacement: step 9, image 3 of 3
      • Continue around the wheel rim until the whole tire is free from the rim. Now you may separate the tire from the wheel.
      • Be careful not to damage the valve stem as you pull the tire and inner tube off of the wheel rim together.
      Ask FixBot
    5. Trek 820 Spokes Replacement: step 10, image 1 of 2 Trek 820 Spokes Replacement: step 10, image 2 of 2
      • Remove the inner tube from the tire by simply pulling it from the tire carcass.
      Ask FixBot
    1. Trek 820 Spokes Replacement, Spokes: step 11, image 1 of 2 Trek 820 Spokes Replacement, Spokes: step 11, image 2 of 2
      • Slowly peel back the layer of rubber that covers the 32 screws on the wheel.
      Ask FixBot
    2. Trek 820 Spokes Replacement: step 12, image 1 of 3 Trek 820 Spokes Replacement: step 12, image 2 of 3 Trek 820 Spokes Replacement: step 12, image 3 of 3
      • Remove the screw using the flathead screwdriver.
      • You will need to alternate between steps #12 and #13 repeatedly because the spokes have to be removed one at a time.
      • All screws will be the same size.
      • Only remove the screws of the spokes you are replacing.
      Ask FixBot
    3. Trek 820 Spokes Replacement: step 13, image 1 of 3 Trek 820 Spokes Replacement: step 13, image 2 of 3 Trek 820 Spokes Replacement: step 13, image 3 of 3
      • Once a screw is removed, if that spoke did not fall out, gently remove it from the wheel.
      • Maneuver the spoke so that it is perpendicular to the plane of the wheel, then slide the spoke out.
      Ask FixBot
    4. Trek 820 Spokes Replacement: step 14, image 1 of 1
      • Insert the new spoke into the empty hole on the hub.
      • If you are replacing multiple spokes, you will need to alternate between steps #14 and #15. The spokes must be replaced one at a time.
      Ask FixBot
    5. Trek 820 Spokes Replacement: step 15, image 1 of 1
      • Use the flathead screwdriver with the screw removed in step #12 to attach the spoke to the wheel, securing it in place.
      Ask FixBot
To reassemble your wheel after following steps #4, and #5 simply reattach the rubber tire.
2 other people completed this guide.
Author
with
Kaveh Karimiyanha
822 Reputation
7 Guides authored
Cal Poly, Team 1-1, Propen Fall 2012 Member of Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 107
All Time: 3,038
