Up to 20% off select tools
Trek 820 Light Mount Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
87
All Time:
1,550
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
You may need to replace the light mount on your bicycle because the light has burned out or you require a brighter light. This guide shows the proper steps to install a replacement Light Mount for a Trek 820 (or similar) bicycle. No tools are necessary for this easy repair.
    1. Trek 820 Light Mount Replacement, Light Mount: step 1, image 1 of 2 Trek 820 Light Mount Replacement, Light Mount: step 1, image 2 of 2
      • Clean the area where the light mount will be installed with a soft cloth.
      • Placing the light mount close to the center stem.
      Ask FixBot
    2. Trek 820 Light Mount Replacement: step 2, image 1 of 1
      • Remove the strap from the light mount fitting.
      • Stretch the strap clockwise around the handlebars.
      Ask FixBot
    3. Trek 820 Light Mount Replacement: step 3, image 1 of 1
      • Slide the strap through the slot and fasten to a snug, but moveable fit.
      • Do not fasten too tight as this will make it difficult to fine tune light mount placement.
      Ask FixBot
    4. Trek 820 Light Mount Replacement: step 4, image 1 of 1
      • Pull the strap tightly through the clasps at the bottom of the mount.
      Ask FixBot
    5. Trek 820 Light Mount Replacement: step 5, image 1 of 2 Trek 820 Light Mount Replacement: step 5, image 2 of 2
      • Place the fastening screw in the rear screw port on the light mount.
      • Twist the screw clockwise using your hands until fully fastened.
      Ask FixBot
Now you have a light mount ready for safer night rides on your Trek bicycle!
Author
with
Kaveh Karimiyanha
822 Reputation
7 Guides authored
Cal Poly, Team 1-1, Propen Fall 2012 Member of Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 87
All Time: 1,550
