Up to 20% off select tools
Trek 820 Handlebars Replacement
Views: 7.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
121
All Time:
7,363
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the handlebar and stem from a Trek 820 or similar bikes that have a thread less stem.
The stem acts with the handlebar to steer the bike in the desired location while keeping the fork and headset attached to the bikes frame. It is important that these steps are done correctly to ensure that the rider is safe while operating this bicycle.
Before using this guide make sure you have the correct size handlebar and stem depending on which item you are replacing.
    1. Trek 820 Handlebars Replacement, Handlebar and stem: step 1, image 1 of 2 Trek 820 Handlebars Replacement, Handlebar and stem: step 1, image 2 of 2
      • Use a 3/16" Allen Wrench to remove the silver cap.
      Ask FixBot
    2. Trek 820 Handlebars Replacement: step 2, image 1 of 1
      • Use a 7/32" Allen Wrench to remove the two bolts; 1 and 2. These clamp the stem to the steerer tube of the fork.
      Ask FixBot
    3. Trek 820 Handlebars Replacement: step 3, image 1 of 2 Trek 820 Handlebars Replacement: step 3, image 2 of 2
      • Remove the handlebar by lifting vertically away from the frame.
      • Be careful to lift up only the handlebars and stem. If you lift up by the frame the headset and fork might come lose.
      Ask FixBot
    4. Trek 820 Handlebars Replacement: step 4, image 1 of 2 Trek 820 Handlebars Replacement: step 4, image 2 of 2
      • To reassemble, slide the stem with and handlebar on to the steerer tube of the fork carefully.
      • Place silver cap on and tighten the bolt with a 3/16" Allen Wrench. This is done first so that the the headset is compressed between the frame and steerer tube of the fork.
      Ask FixBot
    5. Trek 820 Handlebars Replacement: step 5, image 1 of 1
      • By hand you can now adjust the positioning of the stem and handlebar so that is in line with the front wheel of the bike.
      • Tighten the two bolts; [I] and [II] with a 7/32" Allen Wrench . These clamp the stem to the steerer tube of the fork.
      • Make sure that after tightening bolt [II] you go back and make sure you check the tightness of bolt [I] again. Since the bolts are used to clamp, bolt I will usually not be tight enough after tightening bolt [II].
      Ask FixBot
Author
with
Kaveh Karimiyanha
822 Reputation
7 Guides authored
Cal Poly, Team 1-1, Propen Fall 2012 Member of Cal Poly, Team 1-1, Propen Fall 2012
CPSU-PROPEN-F12S1G1
5 Members
84 Guides authored
1 Guide Comment
Always do step 2 before step 1. Otherwise you could damage the stem or steerer tube.
mel2 - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 121
All Time: 7,363
